Been trying to upgrade to one of the others on his page, I have tried this one, beta-0.4.5.1 a few times, but it gets stuck at the M logo.
I am using CWM recovery 5.0.2.7 have done the wipe and install twice with no luck.
I was going to use the 0.5.0 but not sure if CWM recovery would do the trick, I would like to try to upgrade cause the 0.1.0 I am running seems a little flaky.
Am I missing something, or should I go to CWM recovery and just install 4.5.1 over the top without doing the formats????
