I am having trouble with the adb, when I enter the "adb push photon-torpedo.tar /data/tmp" then I get the message "daemon started successfully" after that I get "error: device not found". All the drivers loaded on my system correctly. Any ideas?
Update, I solved this one. I found on other threads that the phone needs ot have "USB Debugging" activated and in "just Charge" mode. Next issue is the error I get when I issue the /data/tmp/photon-torpedo.sh command. I get "ERROR: ld.so: object 'libpcprofile.so' cannot be loaded as audit interface: undefined symbol: la_version; ignored.
Fatal server error:
Server is already active for display 0
If this server is no longer running, remove /tmp/.x0_lock and start again."
What now?
Update: I kept searching different forums and found that this error message can indicate that you have actually rooted your device. Install the app "APP Checker" from the Android Market. When I ran this app, I was told that I was "rooted".
SUCCESS!
