Root Motorola Photon 4G without the HD Dock.
sandtiger
12
13
This will make a bunch of people happy because now you do not need the $100 HD Dock to root the Photon.
Prerequisites
Drivers
32-bit http://bandbinnovations.com/xda/photon/32bit.zip
64-bit http://bandbinnovations.com/xda/photon/64bit.zip
ADB package http://gititbit.ch/AFAS
Root file http://proton.cygnusx-1.org/~edgan/photon/photon-torpedo.tar
Installation
Navigate to the Android Market and install the ?Superuser? application from ChainsDD
Alternatively, install a Superuser .apk file from here. Index of /superuser
Extract the ADB package to your C:\ Drive under a new folder titled ?root?
Place the root file in the same folder
Open the command prompt (Start >> run ?cmd? >> enter)
Type the following commands
cd C:/root
adb push photon-torpedo.tar /data/tmp
adb shell
cd /data/tmp
/bin/tar xf /data/tmp/photon-torpedo.tar
/data/tmp/photon-torpedo.sh
/data/tmp/install-su.sh
Congratulations! You are rooted!
/bin/tar xf /data/tmp/root.tar
This is all courtesy of the crazy hackers over at XDA [ROOT] Photon Torpedo, dockless root access - xda-developers
dsx968
188
I'm really bad with this stuff. I get an error saying that adb is not recognized as an internal or external command, operable program, or batch file.
thinknate
143
8
You got that error... in the command prompt? Did you change directory (cd) to the folder where adb.exe is?
anon(171363)
14
I keep getting an error when I type in adb shell. Is it possible for someone to PM me with some more detailed instructions on how to root this thing. I rooted my EVO and had no issues but I am still new with the Android world. Thanks!
theretailshop1
3
Prerequisites
Drivers
Installation
cd C:/root
adb shell
cd /data/tmp
Not to good with this stuuf, and plus I'm on a Mac trying to do this. Is there anyway someone could post a youtube video on how to do this. Thanks
Reactions: jonathanlc2005
thinknate
143
8
What's the error? Does your device show up when you type "adb devices"? If not, you need to enable USB Debugging under Settings - Applications - Development. (That's a prerequisite that should really be added to the instructions.)
Reactions: anon(171363)
anon(171363)
14
I got it figured out. Someone actually posted a video on Youtube that helped me out. I was making some stupid mistakes!
http://www.youtube.com/watch?v=dS8h7l_KwSw
Reactions: bcbbanga4l
statdoc
109
6
Somebody has to ask this, so it might as well be me. :)
This is my first Android phone. Tell me why I should be interested in rooting the phone? What will it do rooted that it cannot do now?
