Results 1 to 2 of 2
    Default Currently running beta-0.1.0 ICS from Jokersax
    Been trying to upgrade to one of the others on his page, I have tried this one, beta-0.4.5.1 a few times, but it gets stuck at the M logo.
    I am using CWM recovery 5.0.2.7 have done the wipe and install twice with no luck.
    I was going to use the 0.5.0 but not sure if CWM recovery would do the trick, I would like to try to upgrade cause the 0.1.0 I am running seems a little flaky.
    Am I missing something, or should I go to CWM recovery and just install 4.5.1 over the top without doing the formats????
  2. #2
    Bullfrog527's Avatar
    Posts
    ROM
    MIUIv4
    Default Re: Currently running beta-0.1.0 ICS from Jokersax
    you might want to try flashing 0.3.1 first, its in th3bill's fixes thread on xda. a lot of people have used that first and then updated to any of the 0.5.x or even the new 0.6.0
