Results 1 to 9 of 9
    willistheyounger's Avatar
    Posts
    Global Posts
    248 Global Posts
    ROM
    Stock
    Default Downgrade
    So i have the 2.3.5 on my mopho and have been wanting to downgrade the baseband back to 2.3.4 is there a way to do this i have tryed useind the rsd and it never works
    Sent from my SPH-D710
  2. #2
    Bullfrog527's Avatar
    Posts
    ROM
    MIUIv4
    Default
    Nope, you are stuck until someone figures out how to unlock that bootloader
    Sent from my MB855 using Android Central Forums
  3. #3
    TheTolsonator's Avatar
    Posts
    Global Posts
    160 Global Posts
    ROM
    CougarCougar's CM 7.2
    Default
    Yeah, I'm a little frustrated that I accepted the ota, not thinking it would relock the bootloader. Not a massive deal breaker, but I'm a tinkerer, and I can't tinker anymore. Bummer.
    Hopefully someone figures it out, or Motorola fixes it.
  4. #4
    Default
    Is there any way to turn off the OTA's? When my photon was updating it lost power and bricked. Now I have a new one with 2.3.4 and would like to keep it that way.
    Thanks in advance,
    Fuji
    Sent from my MB855 using Tapatalk 2
  5. #5
    tirith's Avatar
    Resident Linux Fiend
    Posts
    ROM
    Stock Touchwiz LJC 4.1.1
    Default
    No idea honestly, but I got a new one with 2.3.4 and haven't been bothered with the ota... And I've had it more than a week
  6. #6
    Default
    Quote Originally Posted by FUJIM0 View Post
    Thanks in advance,
    Fuji
    You can edit your build.prop to show you're on the update already (you have to be rooted), or you can flash the 198_7 sbf via rsd lite (no root, but you may lose your data - I can't remember). You should no longer get update prompts that way.
  7. #7
    Default
    Quote Originally Posted by Bullfrog527 View Post
    How about a hard reset? Would that revert to 2.3.4 or does the OTA overwrite that versions backup aswell?
  8. #8
    tirith's Avatar
    Posts
    ROM
    Default
    Hard reset only brings it to current version, ie, whatever version you were on.
    Thanked by:
    FUJIM0
  9. #9
    Default
    Quote Originally Posted by tirith View Post
    Oh well, guess my wife is stuck with the update.. lol. She'll live. Thanks.
