Low battery indicator for Pokemon Go Plus
kathyathome
Active member
Apr 26, 2011
36
Is there a way to check the battery status of my Pokemon Go? I used an app called nRF Connect from the Playstore (android phone), and it seems pretty complicated to me but I do see under "battery services" 72%, which I assume is the battery level, but I've seen it 71%, 72% and now today 76%, so I wonder if it is actually telling me I have 76% battery left. Battery level should be going down, not up, right? Maybe it means 76% used? I've had the Go Plus since the beginning of the Valentine's Day event and have been using it a lot. Still on the original battery. Works great.
Does anyone have a better way to check battery status? Does anyone know how long the battery usually lasts?
Lucy Davies
1,146
Pretty sure I saw a video about this & on Pokemon go where the pogo plus is connected a battery indicator shows when the battery needs replacing.
fuzzylumpkin
5,555
2,558
113
You are correct.
The cr2032 battery inside the Pokémon go plus lasts a fairly long time, and they're pretty inexpensive to replace.
kirk781
