Results 1 to 5 of 5
    Rocka210's Avatar
    Posts
    ROM
    Stock
    Default Help with Rooting my Droid Razr 4.1.2
    Hello everyone.
    I received the Jelly Bean update on my Razr before it disappeared off of Verizon's site. Some features are bugging me and I would like to root this phone and get a ROM of ICS back. I have found that rooting it will be a little bit more difficult because of the Jelly Bean Update on the phone. Can I root it the same way you root a Nexus or do I just have to wait?
    Thanks everyone,
    R
  2. #2
    Default Re: Help with Rooting my Droid Razr 4.1.2
    Quote Originally Posted by Rocka210 View Post
    Hello everyone.
    Thanks everyone,
    R
    You'll have to wait. The only way to root JB on the RAZR right now is if you were previously rooted on ICS 211 and used OTA Rootkeeper to backup your root. I'm sure you won't have to wait long though.
    Sent from my DROID RAZR using Tapatalk 2
    Rocka210's Avatar
    Posts
    ROM
    Stock
    So you don't think I could root it the same way as the nexus or s2?
    Rocka210's Avatar
    Posts
    ROM
    Stock
    Okay, I've decided to not root it yet but I have a new and much smaller question.
    Whenever I reboot the phone or turn it on, it automatically loads fastboot. How do I change it so it does a normal boot instead defaultly?
  5. #5
    carracerz14's Avatar
    Posts
    ROM
    Arctic HD
    Can't root, and can't go back. You're stuck on jellybean for the time being until it's fastboot able back to ics, if it ever is.
    And rooting will likely be different than any nexus phone or the s2.
    Not sure why it boots into fastboot.
    Sent from my RAZR MAXXIMUS
  1. would like help on rooting droid razr 4.0.4
    By mpierce31 in forum RAZR Rooting, ROMs, and Hacks
    Last Post: 10-16-2012, 11:28 PM
  2. Need Some Help With Rooting Droid X
    By RCastro84 in forum Motorola Droid X
    Last Post: 05-04-2011, 07:11 AM
  3. Help using rooted Droid 2 Global/with AT&T Sim card
    By ringercord in forum Motorola Droid 2
    Last Post: 02-07-2011, 12:58 AM
  4. rooted droid x help?????? PLZ!!!
    By pugzilla in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 01-27-2011, 08:55 AM
  5. Need help with rooting Droid X.
    By Hovik818 in forum Motorola Droid X
    Last Post: 01-27-2011, 01:01 AM
