Results 1 to 19 of 19
- 01-29-2013, 06:03 AM
Thread Author #1
Problem with Bootloader
Hello everyone,
I have a problem with my Razr running 4.1.2. It all started when I bricked it. I then forced a flash of a leaked jellybean to bring it back and it all worked perfectly. The only problem is when I turn it on, it automatically boots into bootloader. I then have to turn it off and do the steps to get it to do a normal powerup. Is it a kernal problem or what is causing this?
By the way, the Razr was running 4.1.2 when I bricked it.
Thanks! - 01-31-2013, 07:09 AM
Thread Author #2
- 01-31-2013, 02:21 PM #3
Re: Problem with Bootloader
Locked bootloader you can't flash kernels.
Sent from my RAZR MAXXIMUS
- 02-03-2013, 07:44 AM
Thread Author #4
- 02-03-2013, 09:23 AM #5
You can't.
- 02-05-2013, 06:03 AM
Thread Author #6
- 02-06-2013, 08:14 PM #7
- 02-06-2013, 08:15 PM #8
- 02-08-2013, 06:07 AM
Thread Author #9
Okay, so the phone is off. I hold the power button to turn it on. I get a message that says,
"AP Fastboot Flash Mode (S) (Flash Failure)
0A.77
eMMC Info: Size 16G
To return to normal mode - first press power key to power down
Device is LOCKED. Status Code: 0
Battery Low
Cannot Program
Connect USB
Data Cable"
I then have to press the power button and turn on the phone into recovery (Using the volume keys). One of the options is regular startup. Then it works normally. - 02-09-2013, 06:00 AM #10
- 02-09-2013, 07:32 AM
Thread Author #11
- 02-09-2013, 12:18 PM #12
- 02-09-2013, 05:20 PM
Thread Author #13
- 02-09-2013, 07:54 PM #14
- 02-10-2013, 05:39 PM
Thread Author #15
- 02-15-2013, 08:28 PM #16
- 02-16-2013, 07:26 AM
Thread Author #17
- 02-16-2013, 02:30 PM #18
- 02-18-2013, 08:42 AM
Thread Author #19
Having problems with Moto Droid/ Screens say Bootloader 2C.6C need help to reinstall
By unspoken213 in forum Motorola Droid Rooting, ROMs and HacksReplies: 2Last Post: 05-18-2010, 03:34 PM -
Text messaging problem with wifi on
By Anubis in forum HTC HeroReplies: 7Last Post: 10-23-2009, 04:18 PM -
Problem with Sprint Hero BlueTooth Pairing
By 7droid-sigma in forum HTC HeroReplies: 3Last Post: 10-12-2009, 04:46 PM -
problems with camera and battery
By piper09 in forum HTC HeroReplies: 10Last Post: 10-11-2009, 05:45 PM -
problem with google sign in: password not valid
By sonali in forum T-Mobile G1Replies: 2Last Post: 06-20-2009, 10:39 AM
Reply
