Please help Droid Razr Bootlooped
So I rooted my phone today. Everything went smoothly. I then downloaded an app called Custom Android Font Switcher. I applied a font and it rebooted my phone on it's on. Problem now is it won't pass the Droid eye screen. It moves and everything but it won't pass it. I have down the Volume keys and power button. I hit recovery and did the Wipe Data and Factory Reset. Then clicked reboot system now. But it didn't do anything. Please please help me. It's been doing this since 4 PM it is not 11:35 PM If you know anything that might help I would really appreciate it =)
Re: Please help Droid Razr Bootlooped
Do you have a rom you can try to put on through recovery?
OK you rooted phone, Did you install a custom recovery like safestrap 3.11 & made a backup (nandroid) before you tried changing/ installing any apps that would change you're system folder (like font switcher)?
Sent from my DROID RAZR using Android Central Forums
You're going to have to use matts utility to take your phone back to stock. You cant use apps like that unless you are on a deodexed rom or you will have problems.
Next time, make a backup with safestrap before you attempt to change anything.
Sent from my RAZR MAXXIMUS ;)
