Results 1 to 17 of 17
    pnicho's Avatar
    Posts
    Carrier
    GummyNex
    Default Battery fell out during wipe, help!
    Well, my battery accidentally fell out while doing a factory wipe and now I can't get the phone to power up to the main screen anymore. I can get into the bootloader menus and that's about it. If I power it up, or do a factory reset, I see the htc logos a couple of times and then the screen stays black....but it's still on...just black. FYI it is unlocked and I ran the Clean flash tool and loaded up Amon Ra before this happened.
  2. #2
    xxfallacyxx's Avatar
    Bearded
    Posts
    Carrier
    Business Sense ICS
    Default Re: Need help!
    Hmmm... I'd say see if you can flash a ROM through the bootloader.
    pnicho's Avatar
    Posts
    Carrier
    GummyNex
    I am missing something about flashing a rom? When I did it with my other phones, I'd be able to access the sd card from the bootloader menu and install it from there. But I don't see the sd card or anywhere to get to it.
  4. #4
    Bearded
    Posts
    Carrier
    Business Sense ICS
    You have to be in the fastboot menu IIRC, and the SD card should be called ext_SD.
    pnicho's Avatar
    Posts
    Carrier
    GummyNex
    Quote Originally Posted by xxfallacyxx View Post
    Oh ok. I finally decided to relock my phone and flash the ruu and that got my phone working again.
  6. #6
    jess701's Avatar
    Posts
    Carrier
    SOMETHING BAD AS
    Hello,
    Well I have some major problems I had ics 4.0.1 loaded on my phone and all i was getting was wifi no verizon signal so I called verizon and they had me do a few things with it and seem to screw it up it loaded up after reboot to the htc logo then a black screen. i tryed to load other roms and factory reset. cant seem to load at all past the htc logo and black screen. Please can someone help!!! Thanks Jess
  7. #7
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    Quote Originally Posted by jess701 View Post
    Hello,
    I'm assuming you're unlocked, rooted and installed a custom recovery like amon ra.
    Sent from my ADR6425LVW using Tapatalk
  8. #8
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    Did you make a nandroid prior to all you problems?
  9. #9
    jess701's Avatar
    Posts
    Carrier
    SOMETHING BAD AS
    I am unlocked and using the pgim.zip how ever type for the recovery zip because clock work didnt work. I can get into recovery and hbot but all my data is erase from sd card so I have nothing to reset the phone with. I am confussed lol
  10. #10
    jess701's Avatar
    Posts
    Carrier
    SOMETHING BAD AS
    Default Re: Battery fell out during wipe, help!
    nope well i thought I had but cant find anything or were to load anything all i get is hbot and recovery and the normal tasks in recovery.
  11. #11
    jess701's Avatar
    Posts
    Carrier
    SOMETHING BAD AS
    now after all the messing around it says battery is to low change battery lol
  12. #12
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    OK I would start from the beginning. Is the roms zip file on your external card? If so boot into recovery and wipe data/factory reset. Then reflash the rom. If necessary flash the appropriate boot image as well
    Sent from my HTC Rezound using Tapatalk
  13. #13
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    You will have to resetup and reload all your apps and data. Make sure once you get setup and functional you make a nandroid.
  14. #14
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    Fyi Clockworkmod recovery has bugs. I recommend Amon Ra Recovery.
  15. #15
    jess701's Avatar
    Posts
    Carrier
    SOMETHING BAD AS
    thanks I think I need to charge it up now for a while then I will try that thank you.
  16. #16
    buckifvr's Avatar
    Posts
    Global Posts
    1,709 Global Posts
    Carrier
    CleanROM 4.5 Pro
    Default
    Good luck
  17. #17
    Bearded
    Posts
    Carrier
    Business Sense ICS
    Charge the phone, then use CleanFLASH to flash the Amon Ra style recovery found HERE
    Once you've done that, access the recovery menu and do a factory reset on the phone.
    Finally, use the recovery menu to flash the ROM you have on your microSD card.
