Results 1 to 5 of 5
    Default Help needed, stuck in bootloop again!
    I've searched these forums for help, nothing found. Here's the deal. S-on, rezound with gingerbread, I installed a Scottsrom with Android 4.0.3 and sense 3.6.
    So I heard that if I lock my bootloader, I can Get 4.0.3 with root access, when I did this, it says re-locked, and its stuck in bootloop.
    When I go to cdm on the computer and type in the "adb mem bootloader unlock" command thingy, it won't turn my bootloader into unlocked, help?
  2. Thread Author  Thread Author    #2
    Default Re: Help needed, stuck in bootloop again!
    I could go to htcdev.com and do the steps on hiw to unlock the bootloader again, which I dont know if that would work since im not running stock.
    I could factory reset/wipe everything, but it wont allow me to do this, says something about a P9086.IMG file not found or incorrect file.
    My other option would be to restore from back up, but with the bootloader being re-locked, I can't open amon ra.
    Im going to try to unlock the bootloader again with following the steps on htcdev.com. Ill keep everyone viewing this thread posted with an update shortly
    ok, so i could probably delete this thread, or keep it up for others who may have a similar situation. i found a fix, it was pretty easy. just go to htcdev.com, sign in, and go through all the steps again on how to unlock the bootloader. phone works fine now. the rom im using is cleanrom developer edition 1.4, go check it out, its pretty sweet, and see ya later!
  5. #5
    piizzadude's Avatar
    Banned
    Posts
    Global Posts
    5,774 Global Posts
    ROM
    Something JB
    Sorry I wasnt around to help but I am glad you got it resolved
    Thanked by:
    BygSii
