DEAL OF THE DAY: Save 60% on the LLOYD Flex Case for Samsung Galaxy S3!
Results 1 to 7 of 7
    Default Battery life
    Seeking opinions on the rom with the best battery life or other ways to get better battery. I don't know what other tweaks to do to my current rom to save more battery. My battery life isn't to bad but it could be better I'm sure
    Sent from my ADR6425LVW using Android Central Forums
    Peace
    Leozdad
    Don't look for a way to make money.
    Find a way to make a living doing what you like to do anyway.
    Otherwise you're just raising ransom to buy back your life
    Rezounding Vigor Rocks!
  2. #2
    MrSmith317's Avatar
    Mr Fix-It
    Posts
    ROM
    Stock Rooted
    Default Re: Battery life
    It's more about the kernel than the ROM and I don't think there was an ICS kernel that you could undervolt. Scott's CleanROM always had decent battery life because Scott keeps his ROMs ... Clean. No extra garbage running on them.
    “Around here, however, we don't look backwards for very long.
    We keep moving forward, opening up new doors and doing new things,
    because we're curious...and curiosity keeps leading us down new paths.”
    -Walt Disney
    Default
    Quote Originally Posted by MrSmith317 View Post
    Yeah my battery life is a bad just thought maybe it could be better
    Peace
    Leozdad
  4. #4
    Damasterjj's Avatar
    Posts
    Global Posts
    67 Global Posts
    ROM
    s-off
    I have read a few thread and so far the best rom with the best battery life are the ones running gingerbread. yes ICS roms will decrease your battery
  5. #5
    Quote Originally Posted by Damasterjj View Post
    Now I find out. I might have reconsidered installing the leak : / Battery life is horrendous for me on the ICS leak. In the past, from Eclair to Froyo, and Froyo to GB, battery life improved. Why is ICS worse?
    Devices:
    Rooted HTC Droid Incredible
    Rooted Nook Color
    Rooted HTC Rezound
  6. #6
    Default
    Not true. Running SlimRom and I get over 3 hours screen on time with almost 0 idle battery drain. As in not even 1% an hour
    Sent from my ADR6425LVW using Tapatalk 2
  7. #7
    twolastnames's Avatar
    Posts
    ROM
    To embarrassed to say
    I just flashed the latest RUU, and a Rom based off of it. I chose slimrom, and it is pretty good. The biggest thing I noticed is heat is a lot less. I can't give you a good battery assessment yet, as I've only run it through one charge cycle. Lot's of dudes are raving about it's battery life though.
    What do you give Akop? A doughnut.....
