Results 1 to 9 of 9
- 11-29-2012, 08:07 AM
Thread Author #1
I need some help from the gurus
ive been running counter shrike aosp for 2 weeks with no major problems. i rebooted my phone last night like i do every night. it went to htc screen then black and nothing happened. pulled battery and tried again...same. went to hboot and tried to go to recovery...nothing. any suggestions? if my phone is bricked then what is the best way to get a new one from verizon (i got insurance).
- 11-29-2012, 01:40 PM #2
Re: I need some help from the gurus
I would try to run an ruu. If it runs, it should fix anything that is wrong.
Are you soff or just unlocked? If you are soff, you will just be able to run the ruu. If you are unlocked, you will have to relock and then run it.
Sent from my ADR6425LVWHtc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
Thanked by: - 11-29-2012, 02:03 PM
Thread Author #3
- 11-29-2012, 06:58 PM #4
- 11-29-2012, 08:51 PM #5
What recovery do you have. If it's clockworkMOD, there is your problem. There is a charging bug in that recovery, I can't remember what the solution is, other than charging your battery some other way than in the phone. If you don't have CWM, not sure what to tell you. XDA may be your only hope, there might be some ADB commands you can run to fix your problems.
With Verizon, just tell em your phone won't turn on. If it really won't, there is nothing really to worry about.What do you give Akop? A doughnut.....Thanked by: - 11-30-2012, 10:45 AM
Thread Author #6
i had amon ra. my rez is dead. i tried everything. now i have two options. pay $99 to get another rez through insurance, or get a new device since my account has an upgrade. that htc dna looks pretty awesome. but if i were to upgrade id lose my unlimited data (which i use). i only use as much data not because i need it but because i can. but i at least need 4gbs (the 2gb plan i fear isnt enough for my wife and i) and that would make my bill go up.
- 11-30-2012, 12:47 PM #7Htc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
- 11-30-2012, 01:03 PM
Thread Author #8
i searched and searched and searched all forums yesterday. i found some people with similar problems, but their issues came right after trying to flash something (mainly recovery). my phone just died for no reason. very strange and frustrating. i got as far as relocking but when i tried to flash the ruu it wouldnt take for some reason. i also managed to break my 32gb sd which didnt help matters lol. i still dont know how that happened. i think it was sticking out just a bit when i tried to remove my battery. i had to use my wifes sd card to try and flash ruu. i found out that thunderbolt battery will work on the rezound. im still torn as to what ill do. i may get rid of verizon all together. i hate them anyways.
- 11-30-2012, 04:09 PM #9Htc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
Need some help with the Revue please - audio and video set up
By asuwookie in forum Google TVReplies: 0Last Post: 12-19-2011, 11:55 AM -
Need some help with the custom recovery
By himynameismike in forum LG Optimus S Rooting, ROMs, and HacksReplies: 23Last Post: 08-12-2011, 06:29 AM -
Need some help from exp Ubuntu/Linux users
By Cubanjinx in forum LinuxReplies: 1Last Post: 07-21-2011, 04:47 PM -
need some help with the radio and PRL's
By jonathanlc2005 in forum HTC EVO 4G Rooting, ROMs, and HacksReplies: 2Last Post: 06-01-2011, 09:44 PM -
Need some help from Android Central
By Gunnyman in forum Acer Iconia A500Replies: 1Last Post: 05-29-2011, 11:18 AM
Reply
