Results 1 to 2 of 2
- 12-20-2012, 11:11 PM
Thread Author #1
HELP!
I have a problem here. I installed RezROM s4 v2.4 zip. Flashed that as well as the kernal zip. It installed and was booting up then is stuck on RezROM device hijack complete. Turned off my phone and HBOOT says main version is older update fail! I do not know what to do and hope i didnt brick it...
EDIT: NVM I had a card reader. Opened it up and removed the PH98IMG.zip file. went to recovery and restored.Last edited by jmez900; 12-21-2012 at 01:10 AM.
- 12-25-2012, 06:56 PM #2
Re: HELP!
Are you s on? If you are then you will have to reboot to bootloader for it to install the kernel and then reboot to the rom.
Also, I think this rom is known for a long first boot...
Sent from my ADR6425LVWHtc Rezound(s-off on ViperRez) ---- Asus Tf300(unlocked on CROMI)
HELP! Need to get G1 Working or Dieter Will Kill Me!
By Rene Ritchie in forum The Android Central LoungeReplies: 156Last Post: 05-19-2013, 08:19 PM -
My Turn - Help Dieter with the G1
By Dieter Bohn in forum The Android Central LoungeReplies: 14Last Post: 04-26-2013, 07:08 AM -
Round Robin: Help Jennifer with the G1!
By gadgetgirl#ac in forum The Android Central LoungeReplies: 54Last Post: 12-14-2009, 08:59 PM -
SOS: All G1, Gmail, Gtalk contacts disappeared. Please help!
By android007 in forum General Help and How ToReplies: 1Last Post: 03-17-2009, 04:28 PM -
SOS: Please Help: IMport SMS from XML file to G1
By android007 in forum General Help and How ToReplies: 0Last Post: 02-06-2009, 11:15 AM
Reply
