DEAL OF THE DAY: Save 28% on the Seidio OBEX Waterproof Combo for Samsung Galaxy S3!
Results 1 to 2 of 2
    Default Root Problem with Admire
    I have a Samsung Admire sch-r720. My carrier is Metro-PCS. I rooted this phone, but something went wrong I think.
    I installed the indulge drivers
    I put the phone in USB Debugging Mode
    I used the Admire Root Windows easy one-click root (run.bat)
    But when I try to run apps requiring root, I get "you do not have root permissions".
    When attempting to root, I get several "permission denied" and operation not permitted errors.
    It appears that I do not have write permissions on the device.
    Here is a snapshot of how my root attempts went.
    error: unknown host service
    "[*] Triggering core dump..."
    [1] Segmentation fault app_process /dev...
    cannot create /data/local.prop: permission denied
    "[*] Rebooting phone. It may buzz a lot and loop on boot. Don't panic."
    remount failed: Operation not permitted
    failed to copy 'su' to '/system/xbin/su': Read-only file system
    Unable to chmod /system/xbin/su: No such file or directory
    link failed Read-only file system
    "[*] Installing Superuser.apk. If this hangs, just cancel it with Ctrl+C after a
    few seconds,"
    "[*] and you'll be finished rooting your phone. Reboot and enjoy."
    1156 KB/s (196521 bytes in 0.166s)
    Error: Could not access the Package Manager. Is the system running?
    "[*] Persistence complete, enjoy your rooted phone!"
    Press any key to exit the script.
    If I attempt to use adb.exe to access the phone, I can see the device, I can explore around it (Thus drivers are working fine) but I do not have SU permissions. When I try to SU, it is denied, and NO I don't get any "allow SU" pop up on my phone, it just instantly denies me.
    C:\Install\Admire Root>adb devices
    * daemon not running. starting it now *
    * daemon started successfully *
    List of devices attached
    R720d7a6a373 device
    As you can see, it sees the R720 Device
    I can browse the device:
    C:\Install\Samsung Kies\Admire Root>adb shell ls -l
    drwxrwx--x system system 2013-03-08 15:04 preinstall
    dr-x------ root root 2013-03-08 15:04 config
    drwxrwx--- system cache 2013-03-08 15:08 cache
    drwxrwx--x system system 2013-03-08 15:04 persist
    lrwxrwxrwx root root 2013-03-08 15:04 sdcard -> /mnt/sdcard
    drwxr-xr-x root root 2013-03-08 15:04 acct
    drwxrwxr-x root system 2013-03-08 15:04 mnt
    lrwxrwxrwx root root 2013-03-08 15:04 vendor -> /system/vendor
    lrwxrwxrwx root root 2013-03-08 15:04 d -> /sys/kernel/debug
    lrwxrwxrwx root root 2013-03-08 15:04 etc -> /system/etc
    -rw-r--r-- root root 6939 1969-12-31 19:00 ueventd.rc
    -rw-r--r-- root root 0 1969-12-31 19:00 ueventd.goldfish.rc
    drwxr-xr-x root root 2013-03-08 15:04 system
    drwxr-x--- root root 1969-12-31 19:00 sbin
    dr-xr-xr-x root root 1969-12-31 19:00 proc
    drwxr-xr-x root root 1969-12-31 19:00 lib
    -rwxr-x--- root root 27427 1969-12-31 19:00 init.rc
    -rwxr-x--- root root 7082 1969-12-31 19:00 init.qcom.sh
    -rwxr-x--- root root 8673 1969-12-31 19:00 init.qcom.rc
    -rwxr-x--- root root 6631 1969-12-31 19:00 init.qcom.post_boot.sh
    -rwxr-x--- root root 1677 1969-12-31 19:00 init.goldfish.rc
    -rwxr-x--- root root 94316 1969-12-31 19:00 init
    -rw-r--r-- root root 118 1969-12-31 19:00 default.prop
    drwxrwx--x system system 2013-03-08 15:04 data
    -rw-r--r-- root root 22740 1969-12-31 19:00 SCH-R720_ROOTING.rle
    -rw-r--r-- root root 14464 1969-12-31 19:00 SCH-R720.rle
    drwx------ root root 2012-06-17 22:17 root
    drwxr-xr-x root root 2013-03-08 15:05 dev
    If I try to change any permissions, etc, I get denied with:
    C:\Install\Admire Root>adb shell chmod 577 system
    Unable to chmod system: Read-only file system
    I can not SU on the device:
    C:\Install\Admire Root>adb shell su
    su: permission denied
    I am not a complete Noob, but this is my first and only android device. I am comfortable with Linux command line stuff, and seem to have a pretty good grasp on the adb shell.
    I seem to be stuck here though.
    Any suggestions?
  2. #2
    Default Re: Root Problem with Admire
    Its WAY easier to just put it in download mode and use Odin to flash cwmr, then install a pre rooted rom(I suggest ctmod)...all the good stuff for admire is over at android forums...get the cwmr image/Odin/ops files there...extract them from zip to desktop, run Odin as admin, for ops select schR720.ops, uncheck one package on left, then click on PDA button and put the cwm.tar file here(ignore image error message) then with USB all ready plugged in computer, take battery out of phone, after 10 seconds put back in, hold camera button down firmly while plugging in microusb into phone, after few seconds will pop up yellow warning...press volume up to continue, when phone says downloading click start in Odin and let it do its thing(make sure yellow com box shows up in top left square, if not ur phone isn't recognised reinstall drivers)...then it will reboot...turn off phone then hold volume down and power and home keys down at same time til u see Samsung pop up and let go...if done right cwmr will boot up...then get the zip for cwmr 6.0.3.0 and install by selecting install zip from SD card...then just find zip of from u want n install same way...you're now rooted
    I should take a bath in tomato juice cuz I always smell like skunk
  1. Root problem with ICS 4.0.4 LG Optimus 2x
    By EvaLotta08 in forum Android 4.0 Ice Cream Sandwich
    Last Post: 12-19-2012, 11:28 AM
  2. after rooting problems with lights on front
    By zombiearmy in forum Verizon LG Revolution
    Last Post: 11-08-2011, 10:36 PM
  3. Problems with rooting
    By Matt_8900 in forum Google / HTC Nexus One
    Last Post: 08-15-2010, 05:28 PM
  4. Problems with terminal after unrEVOked rooted (no su)
    By branded in forum Software Development and Hacking
    Last Post: 07-25-2010, 09:29 PM
  5. Rooted Evo has problem with Market / Free Tethering.. Please Help.
    By bdarknessb in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 06-13-2010, 12:21 AM
