1. Steven Brett's Avatar
    I have recently been receiving notifications saying I "Storage space running out" and I don't know how to make the micro SD card the default storage system, it also won't let me move the applications and other downloaded content to the SD card via application manager.
    I would much appreciate it if anyone can help me A.S.A.P.
    Yours thankfully, Steven
    prashant dasud likes this.
    02-21-2013 12:40 PM
  2. Daniel Ibanhes's Avatar
    Unfortunately Android 4.x does not allow applications to be installed on an external sd card.
    All apps must be installed on internal memory.
    I hope I could help.
    04-16-2013 01:03 PM
  3. MikeOR's Avatar
    Camera DATA (pictures - not the app) should be able to be stored directly onto an external SD card. I've only had my camera for a day, but I will look into it. BTW, the Samsung Manual leaves a lot to be desired.
    Steven Brett likes this.
    05-02-2013 04:19 AM
  4. Mike OR's Avatar
    It's easy! On the main camera screen choose Settings/General/ then click external SD card as your default storage.
    An even easier method is to remove the battery, then replace it when you will be given the option to set your default storage to ext SD card.
    05-04-2013 09:18 AM
  5. prashant dasud's Avatar
    give me guideline to storage path
    11-28-2013 04:53 AM
  6. Tsuki Gallardo's Avatar
    what I did was I move apps to (extSdcard) one by one ,
    just go to *files and then *long press the app you want to move then (click move) after that go to (Sdcard) then click "move here".
    hope that help cuz that's what I did on my phone
    03-14-2014 09:24 AM
  7. Robert Leonardo's Avatar
    This was changed in the last couple of builds. One can now move apps to SD Storage.
    07-23-2014 11:47 AM
  8. Rukbat's Avatar
    Not too cool. SD cards write to the same place all the time, internal storage scatters writes. So by running apps that store data in their own folders, you're killing the card long before it should die. Years before.
    03-21-2015 05:52 PM
  9. Michael Lisle's Avatar
    Tsuki Gallardo, I did it this way to and now all my apps just show the name not the app? and some dont work what did I do wrong? UPDATE I took out my battery for a few minutes and all is good now but how do I get videos music apps and everything ells to download right to the external card because I can only down load things smaller then what data storage is left on my internal memory and that suck because everything I download fill the internal memory up so I need to make everything download right to the external card or make the external card and the internal all the memory as one would be even better why the f*** would android make it like this its a nightmare to deal with how lame?!
    09-19-2015 11:12 AM
  1. How do I put movies onto SD card to watch on my GT2?
    By akren5 in forum Samsung Galaxy Tab 2
    Last Post: 07-29-2015, 01:27 PM
  2. How do we use the sd card?
    By CFar in forum Samsung Galaxy Note 2
    Last Post: 10-04-2014, 04:32 AM
  3. Replies: 2
    Last Post: 12-21-2012, 05:41 PM
  4. How Do I Clone An SD Card?
    By AndroidXTC in forum Verizon Galaxy S III
    Last Post: 10-23-2012, 10:20 AM
  5. How do I switch the sd card with internal
    By jabak3 in forum Optimus V Rooting, ROMs, and Hacks
    Last Post: 01-12-2012, 07:44 PM
