1. Reagan Vater's Avatar
    My samsung captivate glide started to not work properly last week after I took it off the charger. It kept restarting over and over again, and eventually would go to the home screen, but if you hit the sleep/wake button, it would restart this whole cycle. I replaced the battery and it didn't help. I've only had it for 7 months now. Help please?!
    12-19-2012 07:48 AM
  2. AzraelsKiss's Avatar
    Make sure there isn't any debris in the charger/usb port of the phone. Try blowing it out with compressed air and use a small, thin piece of cardboard to try to clean it out.
    If that don't work, it'll probably be a software issue needing a factory reset, or a hardware issue needing repair/replacement. Good luck!
    12-22-2012 11:02 AM
  3. Chris Putnam1's Avatar
    Did u ever resolve this issue? my phone is doing the exact same thing and its driving me crazy! I need to get this to stop! I tried factory reset twice already and it still didi not help. Just wondering if u solved the issue.
    08-14-2013 05:20 PM
  4. edensonjr's Avatar
    my captivate glide is making my head spin it started going off and on i tried factory reset and tried all kind of software upgrade ..i even took it for repair but its still doing the same thing and its anoying me ...whenever i try to make a call it goes of and whenever someone calls it also get off...someone help me here
    01-25-2014 02:44 AM
  1. Horrible Battery Issues - Help please!!!
    By marlin29311 in forum Verizon HTC Thunderbolt
    Last Post: 04-18-2011, 06:52 PM
  2. Strange, annoying Bootstrap issue - help please...
    By Oj467 in forum Motorola X Rooting, ROMs, and Hacks
    Last Post: 01-09-2011, 11:43 AM
  3. Yes, another rooting issue..Help please? [Linux]
    By koinutron in forum HTC EVO 4G Rooting, ROMs, and Hacks
    Last Post: 01-07-2011, 01:18 PM
  4. SD card issues help please!
    By Devtodi in forum Sprint Epic 4G
    Last Post: 09-02-2010, 11:32 AM
  5. Froyo Calendar Issue - Help Please
    By DroidDon2010 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 07-12-2010, 01:48 PM
