News and discussion of the Samsung Epic 4G
  • 1
    Marshmallow SD memory RPM for Epic 4G?
  • 7
    adding different notification sounds?
  • 2
    Glitch in "OK Google"
  • 2
    Epic4g Mic issues
  • 2
    phone only flashes certain roms
  • 5
    google calender
  • 8
    How to 'un-root' Epic 4g?
  • 4
    Used Epic 4G won't make or receive calls
  • 4
    profanity filtering?
  • 2
    Help!
  • 5
    Stock GB27 rooted with CWM
  • 2
    Battery & Protection?
  • 1
    Moved:
    OperationA7X, reaching out for help with rooting.
  • 2
    ROOT
  • Thread Display Options
    Use this control to limit the display of threads to those newer than the specified time frame.
    Allows you to choose the data by which the thread list will be sorted.
    Order threads in...
    Note: when sorting by date, 'descending order' will show the newest results first.
