Been using Alpha for over one month and the only complaint I have is that the battery life is lousy. I shut off all apps when I'm not using them and dimmed the brightness. Sometimes I can't even go the whole day without charging. Are there any other tricks to preserve battery life? Other than that, it's a pretty durable and stylish device.
i suffer no hardships doing this -
Battery Tips for Android
1. Toggle off GPS, BT, NFC, Hotspot/Tethering. Toggle on only as needed. (Switch to "Battery Saving" Mode).
2. Display Brightness - Turn off Auto Brightness and Reduce Setting Bar to Minimum Acceptable to you.
3. Sign out of any unused Google Services like G+, Google Now, etc.
4. Disable Location Reporting/History.
5. Beware of constantly syncing in background Apps and Bloatware like Facebook, Twitter, Google News and Weather, Google Currents, Non-Push Email, etc. Set Sync interval for every 1 hour or more and change settings to stop the syncing of data you don't need. Delete the Apps you never use.
6. Turn Off Hot Word "Hotword Detection" Always Listening Mode in Google Search if you don't use it.
7. Turn Off Auto Camera/Photo Upload or at least set it for Upload on WIFI Only.
8. Turn Off Vibrate on Touch for Display, Keyboard, etc.
9. Turn Off Touch Sounds and Unlock Sounds.
10. Don't use Live Wallpaper. Use a dark wallpaper if possible.
11. Set Display Sleep Setting to 2 Minutes or Less.
12. Set WIFI to Always stay on during Sleep if you regularly use WIFI.
13. Uncheck "Always Scanning" in WIFI settings.
14. Turn Off Always Vibrate in Gmail/Email.
15. Be careful of using too many Live Widgets and what/how often they sync.
16. Set MS Exchange Sync at 30 Days or Less.
17. Do NOT use a Task Killer App or Battery Saver App.
