Battery duration very limited
frankge973
3
Unfortunately, especially after upgrading to Lollipop battery Samsung Galaxy Alpha G850F discharged very quickly and not know what to do :
I have:
1 ) disabled as much as possible ( when not in use ) and the BT GPS
2 ) tried to replace the original battery with a 2850mAh of ( so they say ) not original
3 ) tried to disable both S Voice that Google Now they say consume a lot
4 ) Reduced brightness and battery life activation screen in 15 sec .
The term does not arrive in the evening since it from the detachment at 8:30 in the morning, I get up at 17.30 scarce not use it to call , remaining in the wifi network but navigating virtually nothing .
I'm really confused and do not know what to do . If anyone has any advice and can help me or I know that sooner or later will change phone .
Thanks a lot
frankge973
3
I had a similar issue and a cache wipe fixed it.
Posted via my Galaxy Alpha
I tried that and the only result that I had is continue loop of phone with all app that terminates unexpetclty.
I'd to reinstall Android and all apps and settings.
Battery duration has not changed.
sdmf
260
3
Strange my alphas battery is great. It's actually a bit better than my note 3 if you can believe it. Smaller screen must have something to do with it but still. I'm impressed with mine.
Robbyworkman1995
