Wondering how many have two or more galaxy gear watches. I actually thought about buying another one just to have different color.
I thought the same about the screws but with mic in band not sure if that would be an easy plug and play to different band color.
I currently have black band but would like the orange. If could find for $200 would pull the trigger
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
I don't have two and I won't buy another just to have a different color, but I do wonder if the four exposed screws are not just for style, but also the means by which the band is connected? If so, then it appears at some point there will be interchangeable watch bands to allow users to change up the look from time to time?
Was told today won't be able to change bands
$200? Are you one of the lucky few that was able to hikd T-Mobile to their coupon?
I just want to be able to get a little larger band..
Sent from my iPad using Tapatalk HD
Don't think that is going to be possible with the GG. I am quite sure the band carries all the connections to the camera, mic, etc.
