1. RetroGlide08's Avatar
    As a van driver I'm thinking the Gear could be handy by keeping my phone out of sight in the van as I deliver but I'll still be notified by the watch of calls/messages etc. My question is, if I were to leave the van to make a delivery would I have to reconnect to the phone upon returning to the van? Would I also be notified when I return to the phone of any missed calls via the Gear once reconnected?
    Thanks in advance for any reply 👍
    Sent from my SM-N9005 using Tapatalk 4
    10-10-2013 11:13 PM
  2. Yellowfddriver's Avatar
    Yes. If you walk out of phone range with a gear on, it will disconnect then reconnect upon re-entering range. It connects/pairs w/ your phone via bluetooth. As for "missed" notifications, I haven't seen that happen yet. I'll have to try that part out tomorrow.
    srkmagnus and RetroGlide08 like this.
    10-10-2013 11:15 PM
  3. elvis1935's Avatar
    What happens if you have Ford Sync in your car where with the calls go would you still be able to use sync and the watch to
    Sent from my SCH-I605 using AC Forums mobile app
    10-10-2013 11:21 PM
  4. DAS's Avatar
    The phone can accommodate multiple devices connected via bluetooth.
    I don't have Ford sync, but when driving I do connect my visor bluetooth speaker and haven't had any problems.
    I'm not sure how Ford Sync works, but in principle it should work.
    10-11-2013 06:28 AM
  5. ttexxan's Avatar
    Correct as long as your choosing your primary source when pairing should work just fine.
    Ditto on second comment. When in range will re synch and notify of anything missed
    Sent from my SAMSUNG-SM-N900A using Tapatalk 4
    RetroGlide08 likes this.
    10-11-2013 07:40 AM
  6. elvis1935's Avatar
    But you can't split phone audio twice if Ford Sync has phone audio and media audio can you still keep to watch connected too?
    10-11-2013 11:18 AM
  7. karsdroid's Avatar
    Thanks in advance for any reply 
    says in the gear manger under notifications that the next time they connect anything missed on the phone will show up on the gear....
    10-15-2013 06:59 PM
  8. RBChamp's Avatar
    I have Ford Sync and the watch. Both sync simultaneously and for me the calls defaulted to the Ford sync and the watch was still connected.
    Sent from my SGN 10.1 2014 Edition Using Ac forums mobile app .
    10-15-2013 08:10 PM
  9. Jay Sacks's Avatar
    Lucky you. When I get into my car with Ford Sync I get a message on my phone that says my watch has been disconnected. When I spoke with a Samsung Tech, he said it was 50/50 as to whether it would work or not.
    I am okay with it I guess. Better my watch is disconnected than my Ford Sync not work.
    12-30-2013 05:22 PM
  1. Brand Spanking new phone, lots of force stops, why!
    By pnizzle20 in forum Samsung Galaxy Note 3
    Last Post: 12-01-2014, 11:06 PM
  2. Replies: 16
    Last Post: 10-17-2013, 10:14 PM
  3. Replies: 11
    Last Post: 10-12-2013, 04:08 PM
  4. Newbie Question - Option disappeared
    By Joker8891 in forum Samsung Galaxy Note 3
    Last Post: 10-10-2013, 09:34 PM
  5. Brand Spanking new Note 3, lots of force stops, why!
    Last Post: 10-10-2013, 07:58 PM
