Go SMS and Samsung Gear
RiponOX13
I love Go SMS pro but I do not receive notifications on my watching using this app. I had to uninstall Go SMS to receive the text messages on the watch. Is there any way around this or do you know if Go SMS will be supported in the future?
ttexxan
107
Not sure if it will be supported in the future but I was having same issue and had to return to native app.
Sent from my SAMSUNG-SM-N900A using Tapatalk 4
rough1200
21
The same goes for Handcent. I had to uninstall it in order to recieve tex on the watch! Hope this gets fixed with update before my 30 day return window expires.
DAS
1,130
63
It's not something that's broken. Samsung made the business decision, and they didn't hide the fact, that the Gear is for their native apps only, and a few select partners they collaborated with in their own app store.
You will likely need to return your watch because I don't believe you'll see Samsung change their decision anytime soon.
octobermagic
53
3
www.facebook.com
That's a shame if true. They didn't need to necessarily approach it that way. Just making it compatible to the high end Galaxy line would have done that. I hope they open it up to more apps. i'd love to have Google maps and a talking version of Google Now on it.
imtravis
496
18
I'm sure we'll see more compatible apps for the gear.. Just need patience.. Hopefully a few apps I use will have a gear component son.
Sent from my iPad using Tapatalk HD
mosimann
18
Took me a few minutes but I could make Go SMS and notifications working on the Gear.
On Go SMS:
* Notification Settings:
- Enable Notifications: on
- Default Notif. Settings: disabled Vibrate.
* Other Settings:
- Disable other message notification: unchecked.
On Messages (Stock):
* More
- Notifications: checked.
- Vibrate: checked.
That's it, works fine.
jschu22
565
7
On Go SMS:
* Other Settings:
* More
- Vibrate: checked.
Aren't you getting duplicate notifications then?
TrainerJulieC
12
On Go SMS:
* Other Settings:
* More
- Vibrate: checked.
This also works with Handcent. You just have to turn off the "PopUp Notification"
SeaniB
15
I'm not ready to delete my go SMS yet.... Took me a long time to get my settings just right....
Sent from my SM-N900V using Tapatalk
AmeliaRodriguez
