Results 1 to 24 of 24
    ggrech's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy Gear and S Voice - Note 2 Rogers Canada
    Has anyone else noticed a problem with S Voice on the GG? Even the simplest voice commands are replied with a garbled/distorted "I didn't catch that" response from the GG. I am running the latest 4.3 Android on the Note 2 and latest firmware on the GG?
  2. #2
    cburbee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Gear and S Voice - Note 2 Rogers Canada
    Quote Originally Posted by ggrech View Post
  3. #3
    cburbee's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes exact same problem here on Note 2. Pretty sure it has to do with a glitchy android 4.3 update for the note 2 to give it gear support. I called samsung and they had no clue. Its still too new. A couple more updates and im sure it will work itself out. My wife has a s3 and went to 4.3. Now her camera flash flashes instead of the led on notifications. This is the worst rollout ive seen yet. Hope they have a fix soon.
    ggrech likes this.
    ggrech's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Good to know .... I've tried several fixes (loaded/unloaded various apps thinking that was the cause)
  5. #5
    Murray Simser's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having the exact same problem with my GG/N2. Short of every GG from Rogers being defective I too think it is an update issue.
    ggrech likes this.
  6. #6
    Steve Bauer's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    i am having same issues. . bought a second one to warranty swap myself.. I'm not waiting 14 days.. Samsung was going to make me send it in. .f that. .. And second one does same crap... They Better clue in. .. They can't Fix a prob when they don't know if there is one... That will Take a month for them to clue in...
  7. #7
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I returned mine as well. Second device does the same thing.
  8. Thread Author  Thread Author    #8
    ggrech's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    So did I, same thing here! - I wonder if anyone at Samsung reads these ... ??
  9. #9
    Gary Kapalka's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    talk to samsung and they said it is a problem with the note 2 ,have to wait for firm ware update,they did not say when update would be out
    going to take my back,do not want to wait for months
  10. #10
    bearda's Avatar
    Posts
    Global Posts
    301 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Gary Kapalka View Post
    If it's a phone update that means it has to work it's way through your carrier, as well. Probably a smart decision not to wait around, especially since there's a good change there will either be a Gear price drop, the Gear 2 will be released, or both by the time your phone is ready for it.
  11. #11
    4doorj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am soooo glad I found this thread. It's the only thread on google I have found, nobody else has posted anything else anywhere. I thought I had a faulty galaxy gear, did not want to return it haaha. Galaxy gear is awesome, I know I'm missing 1/2 its capabilities with this stupid s voice gargly voice issue.
    Note 2 users have any other issues?
    I find that my music controller only controls the volume and nothing else.
    I hope this s voice thing is resolved sooner or unless someone else has found a mod to fix it.
    I would love to get google now working on it too! That would be awesome.
  12. Thread Author  Thread Author    #12
    ggrech's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    It should also allow you to skip fwd and back????
  13. #13
    4doorj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yeah it should. But I think the problem is the note 2 and galaxy gear firmware not working good with each other. I could be wrong.
  14. #14
    supremepower30's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    you are right firmware issue with note 2 and galaxy gear,mine is doing the same thing
    taking gear back and will wait for next version
  15. Thread Author  Thread Author    #15
    ggrech's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    The Samsung app store just released an update to "Gear Manager" in an attempt to fix the problem .... it's a bit better - but it still doesn't work
  16. #16
    4doorj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Boooooo! But at least the update makes the battery last wayyyyy longer!
    ggrech likes this.
  17. #17
    rsmin's Avatar
    Posts
    Global Posts
    528 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am with Verizon, and I just got the update for Note 2, my GG is doing the same thing. So I don't believe this is just an issue with Rogers.
    Sent from my SCH-I605 using AC Forums mobile app
    ggrech likes this.
  18. #18
    4doorj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    nice got it working. After the new updatw few daya ago it didnt fix it. But... i found if you uninstall galaxy gear. Reset the galaxy gear. Reinstall galaxy gear. Pair it. It finally works! Soooo happy.
  19. #19
    rsmin's Avatar
    Posts
    Global Posts
    528 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by 4doorj View Post
    Glad you got it working. I didn't have to do that but after the last update mine is working now as well.
  20. #20
    Robert Hagenstein's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have experienced the same behaviour. I picked up a Gear a week ago and paired it with my Note 2 and S Voice sounds like it's transmitting from another planet.
    There are two posts in this thread I'm curious about. The first suggests that uninstalling and then reinstalling the Gear will make S Voice work. What are the exact steps you took to make that happen? I've tried a few times and nothing seems to change.
    The other post suggests that the user didn't need to do those steps because the update made the Gear work. What update specifically is being referred to?
    Cheers!
  21. #21
    4doorj's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This might be over kill but what I did was:
    1. settings
    2. application manager
    3. went to geat manager
    4. clear cache, clear data, force stop , uninstall
    5. on galaxy gear reset in settings
    6. went to samsung apps downloaded galaxy gear and installed
    7. paired
    8. done
  22. #22
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    What update are you referring to specifically? What version of the firmware did you end up with on the Gear?
    Thanks!
  23. #23
    linkkoriri's Avatar
    Posts
    Global Posts
    85 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I've seen this update for the S3, it is a known issue. If you haven't fixed it yet, simply go into settings, accessibility. You will see this feature there (turned off) Turn it on. Reset the phone. Go back in and turn it back off. Reset the phone. and viola, it should stop now.
  24. #24
    Susido's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    linkkoriri, I'd love to know what feature in Accessibility settings you're referring to. I've got an S3 and S-voice on my Gear sounds like garbage, often tells me I'm not connected when I am connected and has great trouble understanding anything I say to it. I've just assumed Samsung just makes a really bad voice recognition feature.
  1. Galaxy Gear watch keeps disconnecting
    By ShelaghDB in forum Samsung Galaxy S4
    Last Post: 12-25-2014, 12:06 PM
  2. Verizon Samsung Galaxy S4
    By jumper809 in forum Marketplace Archive
    Last Post: 12-02-2013, 11:25 PM
  3. Replies: 3
    Last Post: 12-02-2013, 05:54 PM
  4. Galaxy Nexus Questions
    By Jwh1o1 in forum Sprint Galaxy Nexus
    Last Post: 12-02-2013, 02:53 PM
  5. Voice Activation and having a cold....ugh!!!!!
    By str8bucs in forum Moto X (2013)
    Last Post: 12-02-2013, 02:24 PM
