07-31-2014 05:43 PM
79 123 ...
tools
  1. joeco23's Avatar
    What happened to the galaxy gear OTA US firmware update?
    12-16-2013 10:16 AM
  2. nfectgotan's Avatar
    Don't think it has been released yet. With the OTA update to the gear manager and the fact that almost every other country has it already I am assuming it may be releasing soon. I wouldn't hold my breath though. Which is why people are upgrading to UK's firmware for increased notifications. I have done so myself, I have ran into a few problems with phone battery life, something I haven't heard many other people have so use at your own risk.
    12-16-2013 10:21 AM
  3. joeco23's Avatar
    Thanks I don't understand why Samsung has not pushed the update to us here in the States I am glad I got my watch close to Christmas as I will just return it and wait for the second generation watch to come out early next year
    Sent from my SCH-I545 using AC Forums mobile app
    12-16-2013 12:31 PM
  4. nfectgotan's Avatar
    don't blame you, seems as if they don't like giving great stuff to US customers, First it started with the octa core and now they lag on an update. I know its not easy to make an update work for all devices on many different phone connections with different cellular companies but I just don't think they care much for US. You can update to UK MK7 which runs perfectly fine for most peoples Gears. Worse case scenario is if you have a small problem after you MK7 update to UK version you can still return it.
    12-16-2013 12:38 PM
  5. Raptor007's Avatar
    I fully get compatibility issues on the Android phones given the carrier integration, BUT, the GG is not a phone and does not have carrier integration. The mere fact that so many in the US have chosen to update via Odin with the MK7 update proves it. Did it, love it, couldn't be happier with it.
    12-17-2013 08:22 PM
  6. waynew73's Avatar
    According to this CNET article which was published today, CNET did confirm (again) with Samsung that the firmware update is very possible this week. (I think this is a new update from the last one CNET stated). Here's hoping.
    What Samsung needs to do to make Galaxy Gear a hit in 2014 | Mobile - CNET News
    12-18-2013 11:13 AM
  7. joeco23's Avatar
    Let's keep our fingers crossed!
    12-18-2013 01:16 PM
  8. SedahDrol's Avatar
    Just received my gear us mk7 ota update.
    12-18-2013 11:51 PM
  9. Sambo41's Avatar
    I just upgraded my gear to US MK7 using Kies. Being able to read my notifications from Hangouts and Gmail is awesome!
    There are now some additional settings in the Galaxy Gear Manager app and on the Gear itself. For some reason the smart relay feature seems to be disabled.
    12-19-2013 04:55 AM
  10. jwlehman's Avatar
    USA user here... Received my firmware update this morning! Glad I waited instead of sideloading.
    12-19-2013 06:06 AM
  11. joeco23's Avatar
    Looks like the firmware update is finally hitting the USA! Is anyone else getting this message? The software update service is not available. Maximum number of roll-out updates has been exceeded. Try later or update your device using Samsumg Kies.?
    12-19-2013 07:49 AM
  12. joeco23's Avatar
    I just downloaded Kies on both my phone and pc, can anyone tell me how to get the firmware update via Kies?
    12-19-2013 07:59 AM
  13. mcgeorge36's Avatar
    Just updated through Kies. I downloaded Kies on my computer, then connected my Gear with USB. After the normal driver installations and things, Kies recognized the gear. It then stated a firmware update was available. The update took about 10-15 minutes. Can now actually read emails on the gear!!!!
    Sent from my SM-N900V using AC Forums mobile app
    12-19-2013 08:03 AM
  14. joeco23's Avatar
    Are you using Kies or Kies 3?
    12-19-2013 08:08 AM
  15. robrex's Avatar
    Kies not Kies 3
    12-19-2013 08:30 AM
  16. joeco23's Avatar
    Thanks I initially installed kies 3 and it would not work I subsequently downloaded kies and it will now recognize my gear but still will not install the update!
    Sent from my GT-P3113 using AC Forums mobile app
    12-19-2013 09:29 AM
  17. Ladell Johnson's Avatar
    May I ask what Carrier you are with?
    12-19-2013 10:04 AM
  18. mcgeorge36's Avatar
    I am with Verizon. I tried to update through the Gear Manager app, but it kept saying too many updates. I downloaded Kies and it went pretty well from there.
    12-19-2013 10:26 AM
  19. waynew73's Avatar
    Having the same problem. Can't get the OTA because of max number of users, so I installed Kies (not Kies 3) because I'm using my work Mac (instead of home PC) and it says no firmware updates to install. I'm on T-Mobile S4, but my Gear was bought at Best Buy.
    Beyond just launching Kies and plugging in the USB to the phonoe, is there anything else that has to be done to initiate the update.
    12-19-2013 10:53 AM
  20. Brian West1's Avatar
    Galaxy S3 Att 4.3 update and no OTA update for MK7. Has anyone as luck with kies for this device?
    12-19-2013 11:19 AM
  21. floridarick's Avatar
    Yes, You have to plug in the GG not your phone........... You should see the update available once you plug in the watch not the phone.
    Note: You have to be at least 70% charged on the watch or it will give you a error msg........ also make sure to use kies not keis 3. Keis 3 will not recognize the GG.
    totaled likes this.
    12-19-2013 11:23 AM
  22. waynew73's Avatar
    Okay, I feel like an *****! Before seeing your reply, I thought about doing what you suggested and dismissed it, but then read your reply and thought I'd give it a try and it worked immediately. Thanks for this!
    12-19-2013 12:05 PM
  23. floridarick's Avatar
    Is any one getting G-mail notifications after doing the update??? G-mail is all I use for E-mail i am not getting any G-mail notifications at all after the update.
    I am on the phone with Samsung right now & they are saying it is a known Problem!!!!!!!
    Please Help!!
    12-19-2013 12:35 PM
  24. floridarick's Avatar
    I got the update and am not receiving any G-mail notifications at all now.... I do not see any options for G-mail at all now in my gear app on the phone. or options on the watch. Can you help?
    Update:Resolved problem after uninstalling & re installing gear manager app....
    12-19-2013 12:39 PM
  25. Sambo41's Avatar
    Go to the Galaxy gear manager app on your phone. Tap notification . Below the bottom of the list of programs you'll see.'more notifications', tap that and you'll find Gmail and every other app you have installed on your phone. Enjoy!
    floridarick likes this.
    12-19-2013 12:46 PM
79 123 ...
  1. Why I switched from Galaxy S4 to Moto G (in-depth)
    By MrMoto1992 in forum Moto G (2013)
    Last Post: 05-13-2014, 11:24 AM
  2. Samsung Gear won't ring/vibrate when receiving calls
    By Cheimo in forum Samsung Galaxy Gear
    Last Post: 04-13-2014, 01:35 PM
  3. Swiftkey haptic feedback not working since update
    By itsvictoriatime in forum Sprint Galaxy S III
    Last Post: 01-23-2014, 08:32 PM
  4. Galaxy Gear deals?
    By evobassfish in forum Samsung Galaxy Gear
    Last Post: 12-18-2013, 10:55 AM
  5. Replies: 1
    Last Post: 12-17-2013, 10:10 AM
