1. mikephelps5's Avatar
    It was working fine but I left it unplugged for a couple weeks and now it won't charge or turn on at all.
    Any advice?
    Splaktar likes this.
    12-18-2013 09:32 PM
  2. Eclipse2K's Avatar
    How long have you left it plugged in for? A lot of devices needs to be charged for a little bit before they will turn on if the battery dies. Also, did you try another plug?
    Samsung Galaxy Note 3 (Verizon)
    12-18-2013 09:34 PM
  3. mikephelps5's Avatar
    I plugged it in for about an hour. When I plugged it in, I got the little spinning icon. Came back an hour later…bricked.
    I tried 2 different plugs as well as USB to Macbook Pro. Nothing.
    12-18-2013 09:36 PM
  4. mikephelps5's Avatar
    OKAY-Switched to a Motorola charging block and usb and it's charging now. *WTF*
    12-18-2013 09:44 PM
  5. Eclipse2K's Avatar
    Well that's quite strange but I'm sure you'll take it.
    12-18-2013 09:46 PM
  6. mikephelps5's Avatar
    True dat! Just bizarre. C'mon man @ Samsung.
    Eclipse2K likes this.
    12-18-2013 09:49 PM
  7. Bojan Vujmilovic's Avatar
    I'm having the same problem... Though I don't have a Motorola charging block handy to try it. Used it a few times, then turned off for a few weeks, and now nothing. Dead
    12-20-2013 07:53 PM
  8. husa3695's Avatar
    Mine stopped turning on so I contacted Samsung support and they told me to hold the power button down for 3-5 seconds and mine rebooted so now it's back on. I don't know if this will help yours but it won't hurt to try.
    Sent from my SM-N900V using Tapatalk
    12-24-2013 10:42 PM
  9. Eclipse2K's Avatar
    Sounds like your device froze and needed a hard reset.
    12-25-2013 02:32 PM
  10. bladerealm124's Avatar
    Any advice?
    Also having this issue after not using my gear for a few days. Tried two different chargers, cleaning the contacts, and reconnecting several times. Hope someone figures this out, have seen several threads about it recently
    01-06-2014 04:30 PM
  11. ginoancona's Avatar
    yes it seems like if you shut it of for a couple of days it does that my is doing that now its crazy. So I was plugging it in on and off for a 2 hour on and of for the day and in the end it turn on I also used a different plug
    01-23-2014 12:53 PM
  12. gazzaabc's Avatar
    Hi guys I*got my gear out the cupboard the other day and it wouldnt charge or turn on when attempted to charge at a socket?? This is a few weeks old. Take the usb off your 3pin plug charger if u have 1 (samsung s4 charger) and plug the gear into a laptop or a desktop and it will start charging slowly. No idea why this works but it does. I think once it goes completely flat it wont charge at a socket outlet. You will all notice that phones and devices take alot longer to charge on laptops and desktops. I think this may have something to do with it. Charge it to 5% on your laptop or desktop and disconnect it and it will start working in your house sockets (charge alot faster). Happy days
    robbynguyen and dodomisa like this.
    01-25-2014 02:31 PM
  13. Debobrota Saha's Avatar
    I was having the same problem,the Gear was new out of the box and it was not charging.I used the USB from my S4 cord and plugged the gear to my LAptop and bingo it started working again...
    05-07-2014 01:40 AM
  14. tarhounir's Avatar
    I confirm Bingooooooo, It's paradoxal All you have to do when the battery is left drained for a couple of days is to start charging on a Laptop or a desktop with a s4 usb cord for about 10 mn then you continue charge if you like with wall charger
    Regards
    06-07-2014 02:40 PM
  15. JSmurfy's Avatar
    the reickle charge worked like a charm thank you..
    06-16-2014 12:28 AM
  16. dodomisa's Avatar
    Thank you very much you are a star it cahrged perfectly
    06-19-2014 03:24 AM
  17. MADGalaxyGearOwner's Avatar
    Thanks everyone for your post's, however none of them resolved my issue. I believe I figured it out and what the problem really is?
    The PINS on the cradle are the problem.
    I tried different Micro-USB cables and different electrical outlets before reading these posts which frustrated me into steps tried below.
    1.) Check the Gold / Brass round female contacts underneath the face plate to ensure that nothing
    is interfering (Dirt / Dead Skin) with the connection to the PINS.
    2.) Lightly push on the male PINS attached to the cradle and ensure that they can be depressed (Dirt and Dead Skin could be causing improper movement or connection).
    3.) Open your cradle and place your Gear in and lightly with enough force push down and hold, you will notice that the charging notification message appears. Hold for up to 10 seconds and you will notice that 1% charging then 2% and so on charging will appear. This indicates to me that the cradle should be (forced-air) cleaned of any micro-debris when charging becomes erratic or no charging occurs at all.
    After applying step #3 the pins should function correctly and charging should be automatic.
    Hope This Helps someone like me who was ready to give up on Samsung and try another future provider like Apple in which I own absolutely zero apple products.
    Gary Vaughn Grant
    Great White North Canada
    06-21-2014 04:20 PM
  18. robbynguyen's Avatar
    Works like a charm - I tried all my little tricks that turned it on in the past.. NOTHING! even charged it for 3 days straight.. NOTHING! Plugged it into the computer, split second later.. CHARGING! I was shocked (but happy) - so thanks for this and I hope everyone sees this.. W O R K S L I K E A C H A R M !
    07-09-2014 06:13 AM
  19. karsdroid's Avatar
    ok, so charging mine today....was down to 14% so i started charging it....at some point i noticed it was at 34% and a few minutes later had to leave so i thought, well that will get me through for a while. unplugged it but noticed that it was turned off even though i had left it on to charge. one push of the power button did not wake it up, so i held the power button for a reboot....NOTHING. not a bloody twitch. it is dead as a door nail. tried the trickle charge from the laptop....tried charging from battery pack.....tried wiping the pins and charging area on the watch itself. nada....i'm so frustrated. is there no other way to force a reboot?
    07-13-2014 10:28 PM
  20. hotgs's Avatar
    5 seconds worked! brilliant thanks. I am however still concerned with the mini socket of the gear charger for a mechanical breakdown..
    08-05-2014 02:27 PM
  21. karsdroid's Avatar
    so i called samsung.....they emailed a shipping label and i sent it off. got it back fixed in about a week. service was quick and painless....
    08-13-2014 04:22 PM
  22. Cerberus76's Avatar
    One more hear that had a completely dead battery and it wouldn't charge from the A/C outlet but as soon as I plugged it into the laptop port - fired right up!
    08-18-2014 10:33 AM
  23. monkeymagik's Avatar
    Live in Australia and the first Samsung Gear Live i had, had this issue. So I got it RMA'd... and the replacement has the same issue.
    Tried different cables, power outlets, PC and the watch is still bricked.
    Joa in Virginia likes this.
    10-30-2014 05:18 PM
  24. Joa in Virginia's Avatar
    I just bought my Samsung Gear S 2 weeks ago and it already does not work!!!! I cannot believe Samsung can produce this piece of junk and charge $300. It costs them about $70 to produce and they rob people of so much money.....fine that is the way the World turns...but at least produce something that WORKS!! It shut off and now does not go back on at all no matter what I do. I am going back to the famous Best Buy to complain and am prepared to fight until I either get my hard earned money back or they give me another watch. What is the difference of having your wallet stolen by a thug compared to Samsung and Best Buy selling this piece of CR**? NOTHING!!
    05-03-2015 09:59 AM
  25. Nikhil jassal's Avatar
    I didnt charged my Galaxy Gear and it was dead from 1 month. Today when i tried to charge it, i was unable to charge as nothing was displayed on screen. So, this helped me and my gear booted.
    Here is the solution guys, turn on your laptop or PC and plug it with USB cable. For some reasons gear need just a little a little power to turn on.
    try until it wont start. try to press power button while charging it with your PC( i kw its hard just use some tool to press power button)
    This is the only method it would boot up, and when its 5% charged you can charge it with regular power supply.
    Thanks,
    Nikhil Jassal
    10-11-2015 10:13 AM
  1. SwiftKey "Inverted Flow" on Note 3
    By SpookDroid in forum Samsung Galaxy Note 3
    Last Post: 12-20-2013, 09:33 PM
  2. USB 2.0 charging cable testing - results surprised me.
    By Gadgetdude in forum Samsung Galaxy Note 3
    Last Post: 12-20-2013, 03:58 AM
  3. Outdated Android version on AT&T? (4.1.2)
    By Steve Finkelstein in forum HTC One M7
    Last Post: 12-19-2013, 10:47 AM
  4. Thoughts on portal suggestions?
    By toddjy in forum Ingress General
    Last Post: 12-18-2013, 08:56 PM
  5. bluetooth dongle on tablet
    By kassyo in forum General Help and How To
    Last Post: 12-18-2013, 08:47 PM
