Results 1 to 12 of 12
    Angry Gear won't power on or charge
    It was working fine but I left it unplugged for a couple weeks and now it won't charge or turn on at all.
    Any advice?
  2. #2
    Default Re: Gear won't power on or charge
    How long have you left it plugged in for? A lot of devices needs to be charged for a little bit before they will turn on if the battery dies. Also, did you try another plug?
    Samsung Galaxy Note 3 (Verizon)
    I plugged it in for about an hour. When I plugged it in, I got the little spinning icon. Came back an hour later…bricked.
    I tried 2 different plugs as well as USB to Macbook Pro. Nothing.
    OKAY-Switched to a Motorola charging block and usb and it's charging now. *WTF*
  5. #5
    Quote Originally Posted by mikephelps5 View Post
    Well that's quite strange but I'm sure you'll take it.
    True dat! Just bizarre. C'mon man @ Samsung.
    Thanked by:
  7. #7
    I'm having the same problem... Though I don't have a Motorola charging block handy to try it. Used it a few times, then turned off for a few weeks, and now nothing. Dead
  8. #8
    Mine stopped turning on so I contacted Samsung support and they told me to hold the power button down for 3-5 seconds and mine rebooted so now it's back on. I don't know if this will help yours but it won't hurt to try.
    Sent from my SM-N900V using Tapatalk
  9. #9
    Quote Originally Posted by husa3695 View Post
    Sounds like your device froze and needed a hard reset.
  10. #10
    Any advice?
    Also having this issue after not using my gear for a few days. Tried two different chargers, cleaning the contacts, and reconnecting several times. Hope someone figures this out, have seen several threads about it recently
  11. #11
    yes it seems like if you shut it of for a couple of days it does that my is doing that now its crazy. So I was plugging it in on and off for a 2 hour on and of for the day and in the end it turn on I also used a different plug
  12. #12
    Hi guys I*got my gear out the cupboard the other day and it wouldnt charge or turn on when attempted to charge at a socket?? This is a few weeks old. Take the usb off your 3pin plug charger if u have 1 (samsung s4 charger) and plug the gear into a laptop or a desktop and it will start charging slowly. No idea why this works but it does. I think once it goes completely flat it wont charge at a socket outlet. You will all notice that phones and devices take alot longer to charge on laptops and desktops. I think this may have something to do with it. Charge it to 5% on your laptop or desktop and disconnect it and it will start working in your house sockets (charge alot faster). Happy days
  1. SwiftKey "Inverted Flow" on Note 3
    By SpookDroid in forum Samsung Galaxy Note 3
    Last Post: 12-20-2013, 09:33 PM
  2. USB 2.0 charging cable testing - results surprised me.
    By Gadgetdude in forum Samsung Galaxy Note 3
    Last Post: 12-20-2013, 03:58 AM
  3. Outdated Android version on AT&T? (4.1.2)
    By Steve Finkelstein in forum HTC One
    Last Post: 12-19-2013, 10:47 AM
  4. Thoughts on portal suggestions?
    By toddjy in forum Ingress General
    Last Post: 12-18-2013, 08:56 PM
  5. bluetooth dongle on tablet
    By kassyo in forum General Help and How To
    Last Post: 12-18-2013, 08:47 PM
B
