1. Steffen Inderberg's Avatar
    Hey guys!
    I just rooted and installed nova launcher on my gear, and want to remove it because it isn't what i hoped so want to remove it.
    Any one that can help me???
    01-07-2014 05:15 AM
  2. dancing-bass's Avatar
    I have no idea how things work on a smartwatch, but I would imagine you can uninstall it like any other app???
    01-07-2014 07:16 AM
  3. Steffen Inderberg's Avatar
    Nope :/ thats my problem :S I have tought if i could find the apk file and delete that would that work?
    01-07-2014 08:55 AM
  4. JasW's Avatar
    If you sideloaded Nova Launcher on the GG, presumably you did it with ADB via the adb install command. Do the same but this time use the adb uninstall command.
    01-08-2014 12:43 PM
  5. DrSavant's Avatar
    You are far better reading existing threads on xda, than asking here.
    01-08-2014 01:33 PM
  6. spookiewon's Avatar
    Wondershare MobileGo allows you to add & remove apps from your Gear.
    MobileGo - Android Manager to Manage Android on PC | Wondershare
    01-12-2014 07:29 PM
  7. DrSavant's Avatar
    If Nova was installed properly, being moved to /system/app, you cannot use Wondershare to remove it.
    @op - did you do a full install? With moving the apk from /data/app to /system/app, while changing the permissions for /system/app back and forth? If so, you need to use Root Explorer, or any other file manager you used for the installation, to go into /system/app and delete the apk.
    Otherwise, if it's still sitting in your /data/app, you can manually delete it using the same file manager.
    fkpalm likes this.
    01-16-2014 02:55 PM
  8. droid.'s Avatar
    If you have not moved the app using root, then grab the Nova Settings and drop it on uninstall. It will uninstall it.
    02-16-2014 03:59 PM
  9. DrSavant's Avatar
    There is no grab and drop to uninstall on the Gear. If you do it while running Nova and being in it, it wont do anything.
    The proper way to remove it, is to mount the apps folder, while not running Nova, and deleting the Nova apk (that's what I did, when I decided I don't like it and want to go back to stock).
    02-16-2014 08:00 PM
  1. Samsung Galaxy S4 mini - Headphones glitch
    By Igor Savtsenko in forum Samsung Galaxy S4 Mini
    Last Post: 10-29-2014, 05:41 PM
  2. d2spr Galaxy S3 problems with flashing some roms
    By JacobGates in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-16-2014, 10:57 AM
  3. Galaxy Note 10.1 files management issue
    By DiabolikaLIntent in forum Samsung Galaxy Note 10.1
    Last Post: 01-12-2014, 02:49 PM
  4. Replies: 4
    Last Post: 01-07-2014, 09:41 PM
  5. unfortunately com.android has stopped error with Galaxy S4 Mini
    By kashish jain1 in forum Samsung Galaxy S4 Mini
    Last Post: 01-07-2014, 08:27 AM
