Results 1 to 8 of 8
    husa3695's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Galaxy Gear: Flesky
    How can you side load Flesky to your gear. How do you side load the APK on the Gear I'm not rooted nor I don't want to be rooted. Any help will be greatly appreciated thanks
    Sent from my SM-N900V using Tapatalk
  2. #2
    JasW's Avatar
    Posts
    Global Posts
    6,244 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Flesky
    You need to get ADB (Android Debug Bridge) set up on your PC so you can sideload by just connecting your Gear to the PC and adb installing the apk file from whatever directory you've put it in on your PC.
    This guide for installing the Nova Launcher on the Gear will help (obviously, substitute the Flesky apk for the Nova apk): How to Install Nova Launcher on Your Samsung Galaxy Gear
    Note that the USB debug option is not visible on some GGs. This YouTube video will explain how to make it visible:
  3. #3
    chefmorry's Avatar
    Posts
    Global Posts
    635 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Flesky
    I successfully put my GG in USB debugging mode, downloaded the drivers and adb to my laptop. Had no problem sideloading the Flesky apk Yo my gear.
    But what are people using it for? When receiving a Txt, the only options to respond are to send a preset message, or using SVoice.
    From what I've read over at xda, it only works when also sideloading tablet talk. It received mixed feedback.
    Anyone successfully using the keyboard using anything else?
    UsedName likes this.
  4. #4
    mr pnut's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AOKP ROM...
    Default Re: Flesky
    Quote Originally Posted by chefmorry View Post
    I'm able to reply back on hangouts from my gear but I I'm blue tooth tethering
    Sent from my SM-N900T using Tapatalk
  5. #5
    Sammuel1973's Avatar
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Galaxy Gear: Flesky
    Thanks for the thread. I too would like to sideload Flesky, can someone else also confirm you can't use the keyboard to freely type on text messages?!
    Sent from my SGH-T889 using AC Forums mobile app
  6. #6
    area52's Avatar
    Posts
    Global Posts
    270 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Confirmed you can't
    Sent from my SCH-I605 using Tapatalk
  7. #7
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks area and chefmorry. Then what purpose is for?
  8. #8
    Therealm80's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You can type texts on the gear using tablettalk. With null Rom it has stock keyboard and predictable text is good.
