Results 1 to 5 of 5
    Default Remove Galaxy Gear notification icon on device
    Hello android peeps! I have been trying to find a way to remove the galaxy gear icon that's in my notification bar to left corner. I find it makes my device look messy and I can't seem to make it go away. Not sure if you need this info but im using galaxy s3 running 4.3.
    Thanks!
  2. #2
    Default Re: remove gear notification icon on device
    You can try long pressing on the GM app from the notification bar and selecting "app info", from there you can un-check notifications and hit O.K. The problem with that for me is, I find that I access the Gear Manager from the notif bar all day in order to make changes to the Gear (e.g. change watch faces, downloading Gear apps from the Samsung App Store, setting notification alerts for other apps, etc.). The Gear Manager is vital for changing things on the Gear, so I guess you would then just have to constantly open it from your app drawer instead as an alternative.
    Thanks for the reply and I will give this a try. Opening the gear manager app isn't a problem for me because I have it on my home screen
  4. #4
    desdroid's Avatar
    Posts
    Global Posts
    27 Global Posts
    It seems to be impossible to remove Gear Manager from the notification drawer by unchecking the check box.
    How to do it?
  5. #5
  1. S-Planner - remove Facebook birthdays but keep events
    By Adam Jantunen in forum AT&T Galaxy S3
    Last Post: 04-24-2015, 03:07 PM
  2. Using T-Mobile on Verizon Galaxy S4, text and talk work, data does not.
    By insidiouswolfe in forum Verizon Samsung Galaxy S4
    Last Post: 03-23-2015, 07:45 PM
  3. Mobile network not available on unlocked Active
    By Papote1313 in forum Samsung Galaxy S4 Active
    Last Post: 05-28-2014, 08:17 PM
  4. noticed my vibration on gear
    By raydawgone in forum Samsung Galaxy Gear
    Last Post: 01-20-2014, 01:21 AM
  5. Video orientation bug on Moto X?
    By ETPhoneHomeT in forum Moto X (2013)
    Last Post: 01-19-2014, 11:40 PM
