1. cdf3's Avatar
    I have a Galaxy Gear, and I can't seem to find that sweet spot that makes it comfortable for me to wear all day.
    If I put it in the 4th hole, it seems to have a snug fit. It's not squeezing my arm to death, but it could be a tad bit looser.
    If I move it down to 3rd hole, it'll fall on the bone on the back of my wrist when I walk. I wish the holes were't so far apart.
    Is the Gear uncomfortable for you all as well? How are you all wearing it on your wrist?
    01-20-2014 05:42 PM
  2. Kevie Cam's Avatar
    I can rotate between the 3rd and 4th hole depends on how tight I want it, but for a guy my height and size (6'2 / 230) I think I have skinny wrists. Eight way it's still comfortable with no slipping.
    01-20-2014 09:03 PM
  3. tech_fan's Avatar
    I went back and forth on the watch holes adjustment for the first 2-3 weeks. I found what is the most comfortable for me, is on the looser side.
    01-20-2014 09:23 PM
  4. cdf3's Avatar
    After going back and forth between the two holes, I decided to be a little creative. The watch would be a little too snug in one hole, then too loose in the next hole. The sweet spot for me seemed to be between those two holes. I decided to adjust it between those two holes, while using a piece of black electrical tape to tape the band to the inside part of the clasp frame. Since my watch band is black, along with taping it on the inside, I'm unable to see the tape.
    Sent from my SCH-I605 using Tapatalk
    zmann likes this.
    01-29-2014 10:42 PM
  5. zmann's Avatar
    I have the same exact issue as you. On second hole it's a little lose and on the third it is a bit snug.. I will definitely try the black tape method. Good idea.
    THE BEAST,,NOTE 3. SIZE IS EVERYTHING!!!
    02-01-2014 05:31 PM
  6. WinePress's Avatar
    Same here, 2nd hole a bit too tight and the 3rd hole is a bit too loose.
    I just ajust mine between the too depending on how I feel that day
    Sent from my SM-P601 using Tapatalk
    02-02-2014 07:33 AM
  7. cdf3's Avatar
    It's best to use 2 pieces of tape. I took a small piece and placed it the same direction as the watchband where the pin normally goes into the holes. That way if it slips out of position, the pin won't go back into the hole.
    I then cut a 2nd piece that wrapped around the band and metal clasp. I started by laying the tape on the metal clasp, then wrapped it around the band once until the beginning and end of the tape met. Only wrap it around just once. Wrapping it around more than once will make the tape too thick, and will cause issues when tying to snap it shut. I made sure the seem, where the beginning and end of the tape meet, was on the same side as the metal clasp. That way the seem would not be in contact with my wrist. I made sure to tape it on the lower end of the metal clasp to prevent it from popping loose when I snapped it shut. The tape cannot be seen once the watch band is in the closed position.
    I also used electrical tape that didn't leave a glue residue behind. That way if I decide to take it off, my watchband still looks the same.
    My Gear is finally comfortable for me to wear all day with no issues at all.
    02-02-2014 09:01 AM
  1. Multiple widgets on the lockscreen
    By molson622 in forum General Help and How To
    Last Post: 01-22-2014, 12:47 PM
  2. How can I get SMS and voice to work while in France?
    By francesd in forum Google Nexus 5
    Last Post: 01-21-2014, 11:21 AM
  3. No os on my galaxy s3!!
    By FloamAJ in forum Sprint Galaxy S III Rooting, ROM's, and Hack's
    Last Post: 01-20-2014, 07:23 PM
  4. Replies: 2
    Last Post: 01-20-2014, 07:12 PM
  5. black line on screen
    By chirpy basil in forum Other Tablets
    Last Post: 01-20-2014, 04:34 PM
