Unfortunately because you posses an LG Smart phone it can be two things.
It could be that your bluetooth firmware version isn't comparable with multi connectivity
Or more than likely your phone isn't fully compatible with the galaxy gear.
Originally and more than likely still the galaxy gear was designed to only support Bluetooth and NFC compatible SAMSUNG devices. Unfortunately it's hard to say if there is a work around however that is the most likely cause of your connectivity issue.
