Results 1 to 9 of 9
    ateamlawn's Avatar
    Posts
    Global Posts
    138 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Can Galaxy Gear connect to phone at the same time as a Bluetooth headset?
    I'm considering getting the Gear 2 and was wondering will I be able to use my bluetooth earpiece and the Gear at the same time?
  2. #2
    aqwesd's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can G Gear connect to phone at the same time as a BT headset?
    I can with a Gear1 and a Plantronics Legend.
    ateamlawn's Avatar
    Posts
    Global Posts
    138 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thanks. That's was very helpful.
  4. #4
    Sammuel1973's Avatar
    Posts
    Global Posts
    1,063 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Can Galaxy Gear connect to phone at the same time as a Bluetooth headset?
    And depending on your bluetooth earpiece, u can answer or dial a call by a simple tap on the earpiece or voice control. I have a Bose earpiece.
    Sent from my SGH-T889 using AC Forums mobile app
  5. #5
    Elly44's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes, I have multiple Bluetooth devices connected at the same time.
    From my Galaxy Note 3
  6. #6
    JimSmith94's Avatar
    Posts
    Global Posts
    740 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Freeza'sfre3 KitKat 4.4.2
    I have a Plantronics Voyager Pro BT headset and my Gear 2 should be here next week. It sounds like I should be able to answer and/or initiate calls with either one depending on which one I click or tap on. Is this true?
  7. #7
    Sambo41's Avatar
    Posts
    Global Posts
    221 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Yes. I use the new Jawbone Era headset primarily and the Jabra Sport Wireless+ when I work out. They both work great with the watch.
  8. #8
    hirenshah's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have the LG Tone (HBS-730) and if I pair the headphone to my phone the Gear 2 disconnects, and if I paid the Gear 2, the headphones disconnect
  9. #9
    Dominic Tanner's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Unfortunately because you posses an LG Smart phone it can be two things.
    It could be that your bluetooth firmware version isn't comparable with multi connectivity
    Or more than likely your phone isn't fully compatible with the galaxy gear.
    Originally and more than likely still the galaxy gear was designed to only support Bluetooth and NFC compatible SAMSUNG devices. Unfortunately it's hard to say if there is a work around however that is the most likely cause of your connectivity issue.
  1. Replies: 68
    Last Post: 04-24-2014, 01:43 PM
  2. Replies: 4
    Last Post: 04-08-2014, 09:53 AM
  3. Galaxy S4 to Moto G?
    By Kolten Nay in forum Samsung Galaxy S4
    Last Post: 03-30-2014, 11:58 PM
  4. You have a request? We'd like to hear about it.
    By Golfdriver97 in forum General Help and How To
    Last Post: 03-30-2014, 04:18 PM
