1. pilotnh's Avatar
    I am trying to find out if there's a way to set an alarm that will only vibrate on the Gear and keep my phone silent. I have the Gear set to vibrate and that part is no problem. The phone seems to override the fact that I have it set as mute because it is an alarm.
    I am hoping to be able to use the wearable Gear as my alarm clock that doesn't wake my spouse.
    04-09-2014 01:29 PM
  2. chefmorry's Avatar
    Are you setting the alarm through your phone, or through the gear?
    It's possible to set an alarm on the gear only, but it must be done through S-Voice.
    Go to S-Voice in the gear, say set alarm. It will ask you for what time to set it for. I've used it, it works. I believe it had nothing to do with your phone once set.
    Lemme know how it works out for you.
    04-09-2014 10:26 PM
  3. pilotnh's Avatar
    Nope. That didn't work for me. It automatically synced it to the phone and was quite audible. Thanks anyway.
    04-10-2014 12:47 PM
  4. zeuserx's Avatar
    You could try a stand alone Alarm on the Gear. Then you do whatever you want without even needing the phone.
    Sideload "Alarm clock"
    04-15-2014 08:13 PM
  5. Lee Tho's Avatar
    How to side load application for android gear 2?
    04-25-2014 04:40 PM
  6. Larry Blevins's Avatar
    I set the Alarm using S Voice on the Gear 2 but I now cannot find how to cancel it. Any ideas?
    06-16-2014 11:14 AM
  7. Larry Blevins's Avatar
    Sorry for the post as I found out you use the Phone S Voice to delete. The Gear 2 does not support cancelling.
    06-16-2014 11:16 AM
  8. Ray Yuen1's Avatar
    To make your gear vibrate and your mobile stay silent when the alarm is going off. When setting the alarm I choose alarm type 'Melody', then I turn the alarm melody volume to zero. That way the melody is playing but no one can hear it, the mobile doesn't vibrate but my Gear 2 Neo vibrates.
    02-24-2015 05:14 AM
  1. Replies: 19
    Last Post: 01-13-2017, 05:17 AM
  2. Music on SD Card
    By WarrenR86 in forum HTC One M8
    Last Post: 07-21-2015, 04:23 PM
  3. New Theme's on the M8 eventually?
    By AlphaVictor87 in forum HTC One M8
    Last Post: 06-26-2014, 09:57 PM
  4. News on 4.4.x update for the Droid Maxx (No clear date still)
    By SeigaGen in forum Motorola Droid MAXX
    Last Post: 05-05-2014, 06:26 PM
  5. FM Radio turns on randomly when headphones plugged in NO App running
    By Gobucks1234 in forum Samsung Galaxy S4 Mini
    Last Post: 04-09-2014, 09:30 AM
