1. thegame161's Avatar
    It's weird screen is completely black. You scroll to the right and notifications come up along with other options but no time on watch or the wallpaper for my clock
    Update related?
    05-16-2014 05:27 AM
  2. Kelly Burby's Avatar
    Update related?
    Have you tried plugged it in the charging socket your device may have ran out of battery and that's why it is not opening.
    05-16-2014 06:59 AM
  3. thegame161's Avatar
    That's the thing it says 88% battery left and other features work
    05-16-2014 07:01 AM
  4. Kelly Burby's Avatar
    Well, that just takes you straight forward to try factory resetting it.
    05-19-2014 01:18 AM
  5. thegame161's Avatar
    It turns out when I updated the gear manager it deleted watch Styler app.. And that's why it was blank doh
    05-19-2014 02:18 AM
  6. Kelly Burby's Avatar
    Well, now I can only say try factory resetting your smartwatch if that still doesn't helps you out then I am afraid but it looks like you need to goto the nearest customer support for fixing it up.
    05-19-2014 02:32 AM
  1. SD card won't mount, works fine in S4 and on computer
    By Acknown3 in forum Samsung Galaxy S5
    Last Post: 01-12-2015, 11:27 AM
  2. Gear Fit apps
    By JimCurr in forum Samsung Gear Fit 1 & 2
    Last Post: 09-16-2014, 07:09 AM
  3. Switch songs while screen is off.
    By artlu629 in forum Google Nexus 5
    Last Post: 05-22-2014, 10:31 AM
  4. HTC One stuck on HTC logo screen!
    By Rinny-Roo NyanCat in forum HTC One M7
    Last Post: 05-17-2014, 06:23 AM
  5. Volumizr automatically adjusts volume on noise!
    By farhad2161 in forum Android App Inventor
    Last Post: 05-16-2014, 03:54 AM
