03-22-2017 08:32 PM
30 12
tools
  1. Kingjd123's Avatar
    Im talking about this..
    03-22-2017 10:45 AM
  2. Kingjd123's Avatar
    Phone battery setting screenshot
    03-22-2017 10:46 AM
  3. Kingjd123's Avatar
    Screentshot
    03-22-2017 10:48 AM
  4. B. Diddy's Avatar
    It's very unusual for a battery not to drop after 8 hours, even if idle (unless you powered if off).
    A battery drain of 7.8% per hour doesn't mean anything if we don't know what else the phone is doing. If it's completely idle, then I agree, that's abnormal. If you're using it relatively often, then it can be normal.
    03-22-2017 12:35 PM
  5. Kingjd123's Avatar
    But 7.8% per hour is unusual for me because i used different kind of phones and i never faced these problems.
    anyway my phone is in official warranty i will go to samsung support centre.
    And again thanks for your effort...
    B. Diddy likes this.
    03-22-2017 08:32 PM
30 12
  1. wifi won't turn on how to fix? Samsung Galaxy E7
    Last Post: 03-19-2017, 01:05 PM
  2. S7 Drain power fast due to 10231
    Last Post: 03-19-2017, 12:25 PM
  3. samsung camera ek gc100, infected bg mlhiw malware
    Last Post: 03-19-2017, 06:33 AM
  4. why can't my version samsung galaxy 4 won't update itself
    Last Post: 03-19-2017, 02:43 AM
  5. Why can't I factory reset my Samsung S6 phone
    Last Post: 03-19-2017, 02:30 AM
