03-22-2017 08:32 PM
30 12
tools
  1. Kingjd123's Avatar
    I just bought my new samsung grand prime plus (j2 prime) a few days before and 5% battery drain per hour when stand by i'm a user of samsung phones since last 5 years first time i have faced battery drain issue.
    Please help me someone
    Sorry for my bad english
    03-19-2017 05:10 AM
  2. Kingjd123's Avatar
    Please reply someone
    Im in trouble...
    03-19-2017 06:23 AM
  3. Lodingi's Avatar
    Hello and welcome to Android Central. My first thought is a rogue app draining your battery. My second thought is a weak radio signal. Have you recently moved? Are you on a new carrier? Let me know and I'll try to help you figure this out.
    Kingjd123 likes this.
    03-19-2017 06:27 AM
  4. Kingjd123's Avatar
    I dont know which app is drain my phone battery' i'm not moved any where here the same model phone with my cousine his battery is very good.
    Thanks for ur reply
    03-19-2017 06:43 AM
  5. meattray's Avatar
    If you look at your battery stats what is the biggest culprit there?
    03-19-2017 08:17 AM
  6. Kingjd123's Avatar
    Always screen
    Thanks for your reply..
    03-19-2017 09:04 AM
  7. B. Diddy's Avatar
    Welcome to Android Central! Duplicate threads merged.
    The screen will almost always be the top battery user, because it requires a lot of battery to operate. It would help to see more stats. Charge up to 100%, then let it drain to 20-30% with normal usage, without charging in between. Then show us:
    1. The main Settings>Battery screen.
    2. The fullscreen battery graph screen (which shows Awake time and Cell Signal Strength).
    3. The Screen category (to see total Screen On time).
    4. The Cell Standby category, if present (to see Time Without Signal).
    [GUIDE] How To Post Screenshots on Android Central
    You might have to install a 3rd party battery monitor, like GSam Battery Monitor, to get the Cell Signal Strength graph.
    03-19-2017 12:21 PM
  8. Kingjd123's Avatar
    Hi guys notice this today morning i unpluged my samsung grand prime plus from the charger that time battery was 100% i put my phone to pocket.after 2 hours and 23 minutes when i check battery its 87%.almost battery drain 13% in just 2 hours and 23 minutes.5.4% per hour please check screenshot and help me please
    03-20-2017 02:44 AM
  9. B. Diddy's Avatar
    I would still help if we saw screenshots as I mentioned above.
    03-20-2017 10:54 AM
  10. Kingjd123's Avatar
    Yeah i tried.
    03-21-2017 02:43 AM
  11. Kingjd123's Avatar
    Screenshot 2
    03-21-2017 02:44 AM
  12. Kingjd123's Avatar
    Screenshot3
    03-21-2017 02:45 AM
  13. B. Diddy's Avatar
    Sorry if I'm not being clear -- it's better to see the stats after you've gone from 100% down to around 20-30% (not down by 20-30%), so that we can see a better overall representation of what's been using the battery over a full charge.
    03-21-2017 10:21 AM
  14. Kingjd123's Avatar
    Yeah agree i will post soon as you mentioned.but always these three things on top of battery draining issue and today i put another battery to my phone but i seen the same problem.
    Thanks a lot for your reply...
    Sorry for my bad english.
    03-21-2017 12:14 PM
  15. B. Diddy's Avatar
    What 3 things do you mean? Screen will always be at or near the top of battery users, because it requires a lot of battery. The only time you won't see the screen near the top is if you're not turning the screen on very often.
    03-21-2017 12:22 PM
  16. Kingjd123's Avatar
    Today i used my phone normal and gsam app shows wifi awak i never used wifi since 3 days.
    i posted screenshots.
    Mr.B.Diddy help me now please
    03-22-2017 07:19 AM
  17. Kingjd123's Avatar
    Screentshot2
    03-22-2017 07:19 AM
  18. Kingjd123's Avatar
    Screenshot3
    03-22-2017 07:20 AM
  19. Kingjd123's Avatar
    Screenshot4
    03-22-2017 07:20 AM
  20. Kingjd123's Avatar
    Screenshot5
    03-22-2017 07:21 AM
  21. Kingjd123's Avatar
    Screenshot6
    03-22-2017 07:21 AM
  22. Kingjd123's Avatar
    Screenshot7
    03-22-2017 07:22 AM
  23. B. Diddy's Avatar
    GSam can sometimes be a little confusing -- it's reporting that your average screen on time per complete charge is 4.5 hours, which is completely normal. Is that usually the case for you?
    To see if there's any discrepancy with GSam, can you show the screenshots from the phone's own Settings>Battery​ menu?
    03-22-2017 10:20 AM
  24. Kingjd123's Avatar
    I'm not agree with you dear
    Because i have samsung s5 prime last night its battery 31% after 8 hours in the morning the battery still 31%.
    That's why i'm confuse with samsung grand prime plus battery stats.
    03-22-2017 10:36 AM
  25. Kingjd123's Avatar
    Just look at this
    Used 74% in 9h 32m 7.8% per hour
    03-22-2017 10:44 AM
30 12
  1. wifi won't turn on how to fix? Samsung Galaxy E7
    Last Post: 03-19-2017, 01:05 PM
  2. S7 Drain power fast due to 10231
    Last Post: 03-19-2017, 12:25 PM
  3. samsung camera ek gc100, infected bg mlhiw malware
    Last Post: 03-19-2017, 06:33 AM
  4. why can't my version samsung galaxy 4 won't update itself
    Last Post: 03-19-2017, 02:43 AM
  5. Why can't I factory reset my Samsung S6 phone
    Last Post: 03-19-2017, 02:30 AM
