Tap twice to unlock. Can it be disarmed?
Henry Barnett
3
Good morning to you all.
"Tap twice to unlock" pops up just after I initiate a call so it makes it impossable to put the phone on loudspeaker or use any of the options on that screen unless I tap it. It pops up again almost immediately and so I have to tap again before ending the call. It's annoying and frankly do not see the point unless it's a way of adding a few seconds to the phone bill!
I have initiated (settings/accesibility/answering ending calls/) to home key answer and power button end call.
But can the "Tap twice to unlock" pop up be disarmed?
Being new to Android phones I am also wondering if it makes a difference which phone you have. My Samsung Trend Lite has Android 4.1.2 installed. Does that function the same way on all other makes using the same 4.1.2?
steve1084
