Results 1 to 6 of 6
Like Tree2Likes
  • 1 Post By Kevork Jaloian
  • 1 Post By zaid1983
    Kevork Jaloian's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default sound problem
    I installed version 4.2.2 on mega 5.8 dual sim as I use programs like viber and skype there isnt sound on speaker I must turn to loudspeaker but the normal phone calls there isnt any problam on speaker
  2. #2
    zaid1983's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: sound problem
    me i have the same problem any advice asap
  3. #3
    Mohamed EL-Sedeek's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    yes yes yes I have the same problem and i have restore factory setting >>>> the problem still exist >>> any body can help us???
  4. #4
    Catherine Manlapat's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I also have the same problem..Maybe it updated automatically and all of a sudden this afternoon when used viber and skype I cant hear the other person usin the regular conversation. I have to put them on speaker..same waht happened when I used an earphone..I cant hear the other person..for so many attempts during skype call it happened once I heard a sound but its static and a robot like sound..can someone here knows whats going on???
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Install the New uptade it fixed the sound problem I hope there isnt any new diffrent problems in this update
  6. #6
    mullaanish's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Cool Re: sound problem
    Haii, Does Your Headset sound problem solved or what? i am facing the same issue,while using skype and Viber ,i can only hear voice over loud speakers. Will you plze share How did you solved this issue.. Regards Geeson.
  1. HTC ONE Boom Sound Louder
    By zorrowaz in forum HTC One M7
    Last Post: 01-17-2014, 04:15 PM
  2. Problem with OTA
    By daniel178 in forum Verizon LG G2
    Last Post: 01-13-2014, 10:46 PM
  3. Replies: 1
    Last Post: 01-11-2014, 01:38 PM
  4. Problem adding video files to my ASUS HD7
    By Logue92 in forum ASUS MeMO Pad HD7
    Last Post: 01-11-2014, 11:25 AM
  5. WI-FI problem
    By carter17 in forum LG G Pad 8.3
    Last Post: 01-11-2014, 12:46 AM
