Does the 4.0.4 Improve the speaker sound?
Yakuzahi
10
I really want to know if it got any improvement with the sound level.
I know about the Volume+ apps.
I didn't notice much difference in 4.0.4 from 4.0.2 as far as the volume is concerned.
4.0.2 had a much better volume than 4.0.1 .
Not that I know of, but some people are using Volume+ from the Play Store to improve the volume. I haven't though so I can't confirm if it works or not.
I use it and it works well but be careful. I don't use more then a +3 boost because I don't want to damage the speaker and I'm not sure how much it can take.
I use +12 and it's perfect. The speaker can handle high volumes - not sure how it was ever decided to keep it so quiet at full volume.
Many apps and Kernels can help with sound. I am going craze using Franco's kernel. The sound hack is SICK! :D
Sent from my Galaxy Nexus
volume+ definitely improved my sound, actually be careful to use it feels like it can mess up the speaker if i give it to much
I am not using a stock 4.0.4 ROM so that might be why but when both of the ROMs that I'm using upgraded to 4.0.4 I did notice a difference.
r3dpuk3
