I ordered the Trident KRAKEN case with the optional handle/stand and it should be here tomorrow. I needed a rugged case because I use my tablet at my warehouse as well as outdoors (shoot coaching videos for the high school track program I coach for). I'll post my thoughts as soon as I get some time with the case.
I like the case. It's sturdy but a little difficult to put together - it took a bit of wiggling to get the power and volume rocker buttons to fit through the holes. I'd say it took me about 10 min to finish getting it all together. The screen protector is as I expected - a little shiny so there is some glare - but it's responsive to touch. The pen is a little sensitive but works well. It's a little "sticky" so your handwriting needs to be a little deliberate. I am guessing that over time it will calm down and the pen might glide easier. The speaker ports work great and don't hamper the sound at all. Trident says the case is water resistant - like when you get caught in the rain. Could be true because each of the ports have rubber flaps that cover the open ports. The one thing I don't like about those ports is that they don't seal shut by snapping into a locking position.
I also purchased the stand. I like the design and not only does it stand the tablet up in multiple modes (it rotates around so it can stand the tablet on all 4 sides) but it can be used to hang it from the wall or a door knob and it can act as a hand hold. It can be easily removed from the case.
Overall, I like it and will hold out hope that the screen calms down so the pen glides more smoothly.
