1. samhahn2013's Avatar
    hi i just got a SGN 10.1 2014 edition. the main reason for the device is to be able to use the S Note. But the 2014 S Note has a few changes which confuse me. Samsung's support was no help, and nothing about this in the manual either. so pls help.
    specifically, when using the handwriting-to-text to write down an article, it is all crowded in one page and does not automatically split into different pages. when in view mode, it only shows a small part of what written. i cannot turn pages to view more. only when touching a blue triangle at the right bottom corner, a new window pops up in the middle of the screen with the entire article which i can roll down to view. but the words are too small to read. can anyone tell me to solve this problem? thank you in advance.
    11-24-2013 02:47 PM
  2. SwaggerJacker's Avatar
    What do you mean by "write down an article?"
    11-24-2013 04:33 PM
  3. colint3's Avatar
    I had the same problem. The new snote only allows you to have handwriting to text in a text box. You have started writing the way the note 8 works. But on the 2014 you have to create text boxes then finish that piece of writing then create another text box.
    This really made me mad but there is no way around it. I now use another program and not snote.
    03-14-2014 10:11 PM
  4. Jamil Bedeau's Avatar
    What other program do you use?
    03-20-2014 06:28 AM
  5. colint3's Avatar
    I use Jotter Pad X instead of snote.
    03-21-2014 08:44 PM
  1. Moto X - Is Everyone Happy with the new Kit Kat?
    By mississippi45 in forum Moto X (2013)
    Last Post: 01-14-2014, 02:54 PM
  2. Whats wrong with this thing??
    By 1979Pontiac in forum AT&T Galaxy S III
    Last Post: 11-26-2013, 08:38 PM
  3. Help Bricked ?
    By jbrownskunk in forum Sprint Galaxy S III
    Last Post: 11-24-2013, 05:57 PM
  4. Snapchat on GG with S4...
    By htc evo 4g in forum Samsung Galaxy Gear
    Last Post: 11-24-2013, 01:59 PM
  5. Are all note 2 models the same size?
    By PanaWanKenobi in forum General News & Discussion
    Last Post: 11-24-2013, 01:54 PM
