Results 1 to 3 of 3
    Default problem with s pen while in its slot
    New to the note 10.1 2014 and overall very happy but once I place the s pen in its "slot" the device continually beeps and gives the s pen detached message in the upper right corner. Every time I touch the device it gives this message and when I close it down and place it down the message continues to pop up. Almost like it's a loose fit. It even goes off nd wakes the tablet up sometimes while it's just sitting on the shelf. I've looked and unchecked the s pen detection option but no help. Anyone else experiencing this?
  2. #2
    Default Re: problem with s pen while in its slot
    Nope, you definitely need to get this replaced... Might just be the S-Pen (if you have another one you could try it) or the inner sensors. If it's the first, then it's easier to replace, but if it's the latter, the entire tablet better be replaced.
  3. #3
    cordoni's Avatar
    Posts
    ROM
    Stock
    Quote Originally Posted by SpookDroid View Post
    Dido. You got a lemon my friend. Sorry it happened. Just return it to the retailer you bought it from, should still be under warranty.
    "Give it time. You will be assimilated, resistance is futile. You are only here to serve the green R2D2. posted by HKM"
    If someone helps you find an answer, please Thank them with the button in their post.
  1. just rooted verizon gs4 with mk2, cant flash any roms
    By Adamc55 in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-22-2014, 02:49 AM
  2. Nexus 5 Texting with Nexus 7
    By eric0668 in forum Google Nexus 5
    Last Post: 12-18-2013, 12:40 PM
  3. S-note Functionality Crippled In 2014 Version?
    By mkel2000 in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-18-2013, 06:13 AM
  4. Replies: 2
    Last Post: 12-17-2013, 01:51 AM
  5. wont accept pass word. cant acess face book constant warning.... sign in error. ready to scream
    By Jackie Wilson1 in forum Incredible Rooting, ROMs, and Hacks
    Last Post: 12-17-2013, 12:06 AM
B
