Results 1 to 6 of 6
    Default note 10.1 2014 having problems with audio
    hi, i just got my note 10.1 about a week ago, ive been having problems with the audio. volume is to weak, both with the speakers and when using headphones. i can fix this by restarting the device, after restarting its loud and audio is great but after a while the problem shows up again, i have to restart the device again.
    anybody else having the same issue? is there a fix? hopefully by software update, or do i have to send it in for repairs.
    thank you
  2. #2
    Default Re: note 10.1 2014 having problems with audio
    Not having issues with mine... and I use it every morning in the shower hehe so I know the sound is decent.
  3. #3
    what is a while ? few min, few hrs, few days do you have power saving on ?
    sometimes it happens after a few hours, sometimes it lasts until the next day. power saving is off.
  5. #5
    it's possible that a app is causing this when the sounds goes run task manager see whats running, you could also try a factory reset but make sure you backup your stuff first
  6. #6
    Haalcyon's Avatar
    Posts
    Global Posts
    6,214 Global Posts
    ROM
    CM 10.2
    Quote Originally Posted by nettech207 View Post
    A cache wipe in recovery might be just what the doctor ordered.
    g2
    Live long and prosper.
  1. Help with micro SD and movies
    By liddie in forum Samsung Galaxy Note 8.0
    Last Post: 01-12-2014, 01:49 AM
  2. Replies: 9
    Last Post: 01-02-2014, 08:37 AM
  3. I'm lost with my jail break
    By CompMan2012 in forum Verizon Galaxy Note 2 Rooting, ROMs, & Hacks
    Last Post: 12-18-2013, 05:47 PM
  4. DESPERATELY trying to buy NExus 10 3G 32gb in Malaysia
    By JesseKL-Mysia in forum Google Nexus 10 Tablet
    Last Post: 12-18-2013, 02:56 PM
  5. Replies: 2
    Last Post: 12-18-2013, 12:20 AM
B
