Results 1 to 4 of 4
    cwy
    cwy is offline
    cwy's Avatar
    Posts
    Default Making the speakers sound better
    As all of you know, the speakers are not pointing towards you so they may not sound optimal. Sort of like cupping your hands next to your ears so you can listen better. You cup your hands next to the speakers and try to redirect the sound towards you. It definitely makes a difference for me. Of course, it works best when you are sitting down. Otherwise, you tend to hold the tablet on the left and/or right edges, in which case your hands may cover up the speakers.
  2. #2
    Default Re: Making the speakers sound better
    Yup, that's one cool trick. It also works on the S4 (facing stupidly backwards and RIGHT where you put your hand) and even on the Note 3, that while it's pointing forward, it helps to direct the sound more at your face with your hands.
    You could make cardboard 'cones' and stick them to the back to get the same effect but without needing to have your hands on the tablet all the time (not ideal when watching a movie, for instance)
  3. #3
    You're not the first to notice. Check out what this guy invented lol
    Verizon Galaxy Note 2
  4. #4
    And he wants 54k funding? And sell it for 13 bucks??!! Ay Caramba! What the iSheep won't overpay for...
  1. Current best price for the Note 3?
    By MikeNY in forum Verizon Samsung Galaxy Note 3
    Last Post: 02-23-2014, 10:04 PM
  2. Is there any way to center the lock screen clock?
    By jmz768 in forum Verizon Galaxy S3
    Last Post: 12-29-2013, 04:22 PM
  3. Replacement Note has better battery life.
    By qualifyordie in forum Samsung Galaxy Note 3
    Last Post: 12-20-2013, 03:46 AM
  4. Nexus 4 Ear Speaker Not Working
    By FiretoFlames in forum Google Nexus 4
    Last Post: 12-19-2013, 12:14 PM
  5. Replies: 1
    Last Post: 12-18-2013, 06:21 PM
B
