1. Jon234567890's Avatar
    Hi all,
    I am looking to be able to connect my Note 3 and Note 10.1 2014 together via a Cable instead of Bluetooth, however I cannot find a Cable with the correct Plugs, I already have a USB Cable for the Note 10.1 2014, but I then have to use a second Cable from the Note 3 to connect to the Note 10.1 2014 Cable.
    Can you get a Cable with two Plug (male) ends to connect to the two (female) ports of the Note 3 and Note 10.1 2014? Or must I use two Cables?
    the Samsung Note 10.1 2014 uses a Micro type B USB Plug,
    http://images.mobilefun.co.uk/graphics/misc/29425-2.jpg
    but the Samsung Note 3 uses a different Plug, a Micro type B USB 3,
    https://upload.wikimedia.org/wikiped...GP6033_wp_.jpg
    Jon
    12-19-2013 08:35 AM
  2. Misterb's Avatar
    What are you trying to accomplish?
    12-19-2013 12:27 PM
  3. Jon234567890's Avatar
    Hi,
    to Tether the Note 10.1 to the Note 3, so that I can go online with the Note 10.1 - only the Note 3 has 3G not my Note 10.1.
    The Note 10.1 has a much larger screen and much easier to read and work from.
    Jon
    12-19-2013 01:59 PM
  4. Stump3r's Avatar
    Just set up a wifi hotspot on your note 3 and then connect your 10.1 to the hotspot or get a micro usb to female usb adapter for the 10.1, then you can use your note 3 cable to connect.
    12-19-2013 02:06 PM
  5. Jon234567890's Avatar
    Hi, thanks,
    but does Samsung, or an accessory provider, not provide just one cable instead of connecting two cables together, you would have thought that they, or some other company, would have, after all they have manufactured two devices which are advertised as being able to Tether and be Tethered, but yet not actually provide a single cable for it?
    Jon
    12-19-2013 02:21 PM
  6. Misterb's Avatar
    No need for cables. This isn't 2002. Set up the wireless Hotspot on the Note 3, and your Note 10.1 can get on the Internet through it without cables by using wifi
    SpookDroid likes this.
    12-19-2013 03:45 PM
  7. Jon234567890's Avatar
    Hi there
    Bluetooth can potentially be a security risk, of course security precautions should be taken such as turning Bluetooth off when not in use, etc. but by using a Cable as a matter of routine, especially in public places, or in business negotiations... Bluetooth security issues can be overcome - by not using it, and Tethering directly using a Cable; especially important when the onus is on the user of the mobile equipment, not the company he is working for, even if the equipment was provided for by the same company, a bit unfair I think, but that's the way it is.
    Oh well, two Cables it is then!
    Thanks
    Jon
    12-19-2013 05:12 PM
  8. Misterb's Avatar
    Hi there
    Thanks
    Jon
    Am I in the Twilight zone here? I never said blue tooth. I said wifi, which can be set up securely.
    12-19-2013 06:46 PM
  9. ChuckeeDroid's Avatar
    Hi there
    Thanks
    Jon
    Misterb is suggesting a secured wifi hotspot from your phone. I do this all the time in public places. It's far less cumbersome than using a wired connection.
    If you're running the hotspot for a long time, you can even charge your phone while it's acting as the hotspot.
    Sent from my SM-P600 using Tapatalk 4
    12-19-2013 07:09 PM
  10. SpookDroid's Avatar
    Still don't think it's the best idea (I'd rather use the WiFi hotspot like the other posters suggest... you're still using a wireless connection to your phone, and that's always a security concern). But here you go:
    USD$1.50 - Micro usb Male to Male Adapter Cable For MHL Mobilephone - lunashops online shop
    12-19-2013 08:21 PM
  11. Jon234567890's Avatar
    Hi,
    Thanks SpookDroid, that's pointed me in the right direction.
    Jon
    12-20-2013 11:49 AM
  12. pcbtmr's Avatar
    Question: What app do you use that addresses the tetheriing ports where both ends are Android? Most wired tethering is PC/Android not Android/Android.
    12-20-2013 01:00 PM
  13. Stump3r's Avatar
    No app required. When you plug in it automatically tethers the 10.1 to the N3, or you can toggle it in settings.
    12-20-2013 04:46 PM
  14. SpookDroid's Avatar
    I wonder if this requires the cable to be OTG or not (the pin setup is the same but the "Sense" terminal is grounded on OTG while 'floating' on a normal cable). Mmmmhhh...
    12-20-2013 09:37 PM
  1. Galaxy S3 wifi keeps connecting after I turn it off!! Help!
    By usmdesigner in forum Samsung Galaxy S3
    Last Post: 07-19-2016, 12:46 AM
  2. Quick access to flashlight + screen brightness tips?
    By Steve Finkelstein in forum HTC One M7
    Last Post: 05-04-2014, 11:01 AM
  3. Note 3 location problems
    By coach_u in forum AT&T Samsung Galaxy Note 3
    Last Post: 01-31-2014, 04:55 PM
  4. screen shot nexus 10 problem
    By joetheghost in forum Nexus 10 Rooting, ROMs, & Hacks
    Last Post: 12-19-2013, 08:10 AM
