Results 1 to 12 of 12
Like Tree2Likes
  • 1 Post By DuStU
  • 1 Post By Haalcyon
    Default Easily identifiable difference bewteen the Note 10.1 earlier and 10.1 2014 edition
    I found a galaxy note 10.1 for sale. I have put my hands on it and checked it out and all appears flawless and properly functioning. The price is great. When I go back to look at it I want to be able to tell if it is the 2012/2013 version or the 2014 version. Is there a simple way for me to determine that not having one of each in my hands? Thanks in advance.
  2. #2
    Default Re: Easily identifiable difference bewteen the Note 10.1 earlier and 10.1 2014 edition
    I would say the easiest way would be the model #, in the General Settings area,,, the 2014 is Model SM-P600
    The previous one was model GT-N8010
    Im a Teldy a TEchnical oLDY . My love of the telephone started in 1952, when I got to talk to my grandma as seen in my avatar. .
  3. #3
    Also the back on the 2014 edition is the fo leather feel to it while the older version has the glossy back to it and the s-pen is in a different location
  4. #4
    Also I believe the s-pen can be docked either way ala note 3 on the 2014. Whereas the last model could not.
    Sent from my Nexus 7 (2013) using AC Forums mobile app.
    Thanks all. It is greatly appreciated. In your more educated opinions than mine, is the non-2014 edition, in mint condition, worth $300?
  6. #6
    is it the 16gb or 32gb? I guess 300 is a good price for the older model. a good deal for the 16gb, a great deal for the 32gb
    It is 32GB with original accessories and folding cover.
  8. #8
    I'd say go for it :-). if you don't need/want/crave the extra power and features of the 2014 , and rather hold onto the extra 250 bucks , 300 for a very nice tablet is a very good deal
  9. #9
    DuStU's Avatar
    Posts
    Global Posts
    137 Global Posts
    Easy way old version speakers on the front. 2014 speakers on the side. I Love this tablet it is a beast!
    SpookDroid likes this.
  10. #10
    Haalcyon's Avatar
    Posts
    Global Posts
    6,212 Global Posts
    ROM
    CM 10.2
    Quote Originally Posted by dianehelen View Post
    I'd be cautious as you don't know what the state of the battery is on an older used model. Is it still at or near full potential or has it been charged/discharged so many times that you can now only get 70% of the original battery life? ...just something to consider.
    CM on OgPro
    Live long and prosper.
    Thanked by:
  11. #11
    Also a new will at least come with a warranty
  12. #12
    I'm late to the party, but I would say the easiest way to check is to look on the bottom edge of the device to see if the charging port is a micro-usb port or the larger 30-pin port. The 2012 model still had the 30-pin connection.
    Anyway, did you get the device?
  1. How do I permanently prevent Note 2 from OTA updating to 4.3?
    By badkitties in forum Verizon Galaxy Note 2
    Last Post: 03-11-2014, 07:21 PM
  2. Can I root my att Note 3 w/out Samsung finding out?
    By CeasarNY in forum Android 4.1 / 4.2 / 4.3 Jelly Bean
    Last Post: 12-24-2013, 01:33 AM
  3. Replies: 2
    Last Post: 12-22-2013, 01:18 PM
  4. Does changing the battery reset personal preferences?
    By NJRonbo in forum Samsung Galaxy Note 3
    Last Post: 12-22-2013, 04:08 AM
  5. Using Hangouts as the default SMS app
    By salutcemoi in forum Samsung Galaxy S4
    Last Post: 12-21-2013, 10:56 PM
B
