Results 1 to 4 of 4
    Default Keeps showing battery indicator on boot
    So I just ordered this from costco (can only get online) and I've been charging it for a few hours now and decide to turn it on for the first time while it's still charging. I hold the power button and it shows the battery icon and then shuts off. I try it again and same thing. I thought holding the power button for like 5 seconds turns on the device?
    Edit: Ok so I unplugged and now I turned it on. Is this tablet not designed to turn on while it's plugged in?? O.o
  2. #2
    Sizzers's Avatar
    Posts
    Global Posts
    316 Global Posts
    Default Re: Keeps showing battery indicator on boot
    This spooked me the first time I came to charge my phone from dead and decided to turn it back on after a while.
    IIRC I kept the power button pressed down and eventually the boot up screen started. Don't know if its a bug or what but it was quite worrying at the time.
    Putting out fire with gasoline
  3. #3
    It's a Sammy problem. If you time it just right while plugged in it will work. Far as I know this has been around since the days of the replenish my first phone which had this too.
    From mah shiny new Nexus 5
  4. #4
    This is not spooky, not a faulty device... if you press the power button while charging, it'll show the battery indicator. If you keep it pressed, the phone/tablet will boot. Same thing if it's not plugged in; the device won't turn on with just a slight press of the power button (granted, it takes a tad longer while plugged in because it first shows you the progress).
    Thanked by:
  1. World of Warcraft on my 2012 N7?
    By Danny Vaper in forum Google Nexus 7 Tablet (2012)
    Last Post: 01-08-2014, 10:29 PM
  2. Replies: 10
    Last Post: 01-02-2014, 12:29 PM
  3. Problem with wireless charging on note 3.
    By trucksmoveamerica#AC in forum Samsung Galaxy Note 3
    Last Post: 01-01-2014, 06:27 PM
  4. Moto X ad in Times Square shows nicely on CNN
    By GadgetGator in forum Moto X
    Last Post: 12-31-2013, 11:26 PM
  5. Keep mobile network on with wifi?
    By music_man185 in forum General Help and How To
    Last Post: 12-31-2013, 08:42 PM
B
