01-05-2014 11:51 PM
40 12
tools
  1. robbielyn's Avatar
    I've read on here what to do. My android settings is set to accept unknown sources. I've downloaded dolphin browser went to Web content enabled desktop, and flash player set to on demand, downloaded apk and it still won't work. It says no application to open and this device doesn't support flash i tried mozilla as well set settings according to directions on here and it won't open. I downloaded boat browser but that browser acts all buggy on my tablet so i took it off. Last night when i tried to watch a flash video dolphin crashed twice. Do i have a lemon maybe? I got tnis a few days ago from amazon. If anyone has suggestions I would really appreciate it. thanks. I'm also experiencing some lag and i turned animations off turned off unnecessary apps including my magazine. I amusing nova launcher as well.
    01-04-2014 06:13 AM
  2. dianehelen's Avatar
    After you download the apk file, you must run it. Think of it like a setup.exe file(in windows speak), it has to run to install. Find it, probably in your download folder, and tap on it. Once it installs go back to either dolphin or, I prefer Firefox, and check the settings. It should work then.
    01-04-2014 06:43 AM
  3. SpookDroid's Avatar
    If you turned off My Magazine, I assume you're rooted? In any case, remember that just because you CAN install Flash doesn't mean it will be perfect. Flash is LONG GONE, support for the plugin is dead for Android for over a year now, and any installation is bound to be buggy. Sorry to be blunt, but it is. It's like installing software from 1995 onto Windows 8 and expecting a perfect experience.
    moosc likes this.
    01-04-2014 09:21 AM
  4. robbielyn's Avatar
    No I'm not rooted. Just stopped it from running due to people saying on that it causes lag. Download says save only no run option. I tried Firefox as well says this device not compatible.
    01-04-2014 09:42 AM
  5. dianehelen's Avatar
    you won't see a run option. you have to find the download file thru a file manager, I use astro file, but I think the Note comes with My Files. Look in the download folder for the file, and tap it.
    here is what the install dialog looks like from My Files , download folder
    SpookDroid likes this.
    01-04-2014 11:15 AM
  6. SpookDroid's Avatar
    Well, that's my question...if you're not rooted, how did you stop MyMagazine from running? The "Turn Off" button is grayed out because it's considered a system file.
    01-04-2014 12:08 PM
  7. dianehelen's Avatar
    maybe the OP just did a force stop, thinking that turns out off?
    01-04-2014 12:26 PM
  8. robbielyn's Avatar
    Yes I did a force stop that doesn't turn it off?
    01-04-2014 12:41 PM
  9. robbielyn's Avatar
    I did that. All I get is a white screen with a dinky download icon in the middle. I hit that and I get flash player settings but when I go to the website baynews9.com and play news videos it won't play them.
    01-04-2014 12:49 PM
  10. dianehelen's Avatar
    what is the exact name of the apk file that you downloaded? it should be: install_flash_player_ics.apk
    01-04-2014 12:58 PM
  11. dianehelen's Avatar
    no. force stop just will force a quit in an app that gets stuck or is not running properly. it does not stop the app from running
    01-04-2014 01:03 PM
  12. dianehelen's Avatar
    Oh here is something else to check. On Firefox, as well as other browsers, for flash to work, you have to be loading the desktop view version of the page. I just tried it with that setting not checked, and tried a video on the bay9 site and it did in fact crash the browser. Checked the desktop view, tried again, perfect flash.
    01-04-2014 01:25 PM
  13. SpookDroid's Avatar
    Force Closing MyMagazine will stop it, for a while... but since this is a system process (for some reason), TouchWiz restarts it eventually, so it will run again. The only way to turn an app off is to, well, turn it off in the Application Manager. Problem is, unless you're rooted, system apps cannot be turned off (and most shouldn't really, unless you want your phone to malfunction, but in the case of MyMagazine it's just a dumb imposition).
    01-04-2014 01:45 PM
  14. robbielyn's Avatar
    Ok I put desktop on Firefox here is what happened. The commercial ran but the picture lagged behind the voice a little. Then when the actual news video came on I heard the voice but video screen was black
    01-04-2014 01:50 PM
  15. robbielyn's Avatar
    I have 32GB version. My signal not real strong in the bedroom. I have bright house cable owned by Timewarner. I have a router modem combo box running 30mpbs. I don't know if medium to weak depending on the time of day. I tell u this wondering if signal could be the issue.
    01-04-2014 01:56 PM
  16. dianehelen's Avatar
    weak signal can affect playback. But it sounds like some progress with flash and Firefox in desktop view. Try going to hbo.com
    if it waits a bit, then you get a gray spinning circle, then the hbo main page, flash is working.
    here are the 2 versions of hbo.com
    01-04-2014 03:08 PM
  17. dianehelen's Avatar
    is your bedroom far from your router? May want to consider a WiFi repeater,
    01-04-2014 03:09 PM
  18. robbielyn's Avatar
    Yes it's far from bedroom
    01-04-2014 10:31 PM
  19. robbielyn's Avatar
    I got non flash on hbo.com
    01-05-2014 06:54 AM
  20. dianehelen's Avatar
    Wow what a bummer and mystery. What I do in these situations is re trace my steps and start from scratch.
    Uninstall Firefox
    re download a fresh copy of the file install_flash_player_ics.apk
    reinstall Firefox
    go to my files and find and install install_flash_player_ics.apk
    go to the settings on firefox, and plugins and enable flash
    Try again. I really feel for you, I KNOW how frustrating it is to try to do something that seems like it should be so simple and seems to be working for others. I have been there myself, but eventually perseverance pays off! Hope you get it.
    01-05-2014 07:09 AM
  21. robbielyn's Avatar
    Can you please provide the link for flash?
    01-05-2014 07:21 AM
  22. dianehelen's Avatar
    Im gonna PM you a a copy of it, as I cant easily locate an easy link. This is one I know works, and I keep it in my dropbox for when I get a new device..
    Hmm guess you cant send an attachment. Do you have an email you can PM me? and I can send it.
    Ahh found it
    install_flash_player_ics (19).apk - 4.49 MB
    01-05-2014 07:37 AM
  23. robbielyn's Avatar
    Ok I finally downloaded the right apk now it's asking for plugin and I have it enabled in my Firefox settings
    01-05-2014 07:43 AM
  24. dianehelen's Avatar
    and????? drumroll... do we HAVE sucess?
    Btw where in the bay area are you? I spend half my time on St Pete Beach
    01-05-2014 07:57 AM
  25. robbielyn's Avatar
    I'm from Sprin hill cold country lol. I not try it because flash says need plugin even though I have it enabled in settings. Bow thanks for all your help
    01-05-2014 08:02 AM
40 12
  1. screen help
    By mcruz78x in forum Samsung Galaxy S3
    Last Post: 01-04-2014, 01:48 PM
  2. please help
    By Sean Mansfield in forum Samsung Galaxy S4
    Last Post: 01-04-2014, 10:49 AM
  3. Replies: 7
    Last Post: 01-04-2014, 08:35 AM
  4. Help with tethering kindle fire hd- smartphone or mifi?
    By Aiyana Leigh in forum General Help and How To
    Last Post: 01-03-2014, 08:51 PM
  5. need link and help for ruu 2.3.5 on desire s
    By hillyboy in forum HTC Desire S
    Last Post: 01-03-2014, 08:31 PM
