Results 1 to 8 of 8
    flybub's Avatar
    Posts
    Global Posts
    469 Global Posts
    Default YouTube problem
    Hey all. For the most part I have been very pleased with my Note, however, there is an issue that is driving me crazy. The YouTube app on this thing is awful! It doesn't matter if I open a video from the web, Twitter, Facebook, or the yt app itself, the only thing I get is sound and a black picture. I have cleared cache uninstalled and reinstalled but it doesn't change anything. The same videos I can open on my s4 and they play without a problem. Am I the only one having this problem?
  2. #2
    Default Re: YouTube problem
    Try a system cache partition wipe, which is different from clearing the app cache. You won't lose any personal data or settings.
    - Turn Off your Samsung Galaxy Note 10.1 device.
    - Wait for 10 seconds, Then move to the next step.
    - Press and hold Volume Up key + Power key.
    - Keep pressing the above keys until the Samsung Logo appears,Then release Power key only.
    - When you see Factory reset / System Recovery menu on screen release the Volume Up Key.
    - Use Volume Down key to select Wipe Cache Partition option.
    - Use Power key to confirm the operation.
    - After performing the hard reset, Select Reboot System Now option, And confirm it using Power key.
  3. #3
    Sounds like a Flash problem....black screen while video is playing.
  4. #4
    Default
    But Flash shouldn't matter for the YouTube app, right?
  5. #5
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,729 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    Quote Originally Posted by B. Diddy View Post
    I think that is right. I think YouTube uses HTML.
    flybub's Avatar
    Posts
    Global Posts
    469 Global Posts
    Hey all, thanks for the replies. B. Diddy I did the system cache partition wipe and it worked for about 3 videos. It's now back to doing the same thing. It is a strange issue because there are times where the video will start to play with both sound and picture then the picture will either completely freeze in that frame or go black but sound continues to play as normal. I can load same video on my S4 and it plays (both picture and sound) without any problem. Any other suggestions don't hesitate to fire them at me, I'm out of ideas. Thanks
  7. #7
    Have you tried clearing the app's cache in Application Manager? If that doesn't do it, try logging out of your account in the YouTube app and re-logging in. If not, then go ahead and clear cache (again) AND data from the Application Manager. If that doesn't do it, uninstall the app, restart your phone, re-install. I've never had issues with mine...
  8. Thread Author  Thread Author    #8
    flybub's Avatar
    Posts
    Global Posts
    469 Global Posts
    Quote Originally Posted by SpookDroid View Post
    I have cleared the cache in the app through app manager but it didn't fix it. Will try uninstall and reinstall when I get home today. Thanks
  1. Nexus 5: Signal Problems
    By gidgiddonihah in forum Google Nexus 5
    Last Post: 09-05-2014, 09:33 AM
  2. d2spr Galaxy S3 problems with flashing some roms
    By JacobGates in forum Sprint Galaxy S3 Rooting, ROMs, and Hacks
    Last Post: 01-16-2014, 11:57 AM
  3. Battery problem after 3 days?
    By f2k8 in forum Moto G (2013)
    Last Post: 01-14-2014, 03:44 PM
  4. Bluetooth keyboard problems
    By brymanda in forum Samsung Galaxy Note 8.0
    Last Post: 01-09-2014, 03:54 AM
  5. Problem with My FIles on ATT Galaxy S3
    By Wayne Craig in forum AT&T Galaxy S3
    Last Post: 01-07-2014, 12:54 PM
